sizeof
sizeof as byte
sizeof
Posted: 04.02.2013 - 12:18  ·  #1
Hi Rolf.
For most structures sizeof(...) returns a value of less than 256, so it would be nice if the following were allowed without error
  iLen : byte;
  iLen := sizeof( ...);
provided, of course, that the result (which is, after all, a constant, albeit one calculated by the compiler) was less than 255.
One can, of course, use
  iLen : byte;
  iLen := byte(sizeof( ...));
but it is less elegant, and actually less safe, because if the structure happens to be more than 255 bytes the above is legal but wrong.
Also in structures like
  i : byte;
  for i := 0 to sizeof( ...) - 1 do
rather than
  i : byte;
  for i := 0 to byte(sizeof( ...)) - 1 do
which is quite ugly.
Obviously not an important or urgent refinement...
Re: sizeof
Posted: 04.02.2013 - 14:07  ·  #2
Hi Merlin,
you suggest that this function result should be dependend of the destination size?
If the destination is a byte then SizeOf(byteType) should be a byte.
If the destination is a word then SizeOf(byteType) should be a word.
And if the result is a word (SizeOf(wordType)) and the destination is a byte the
compiler raises an error.
If the result is a byte and the destination is a word it should work as already does.
Right?
But it must be clear that no byte of code then is saved. It is only optical...
Re: sizeof
Posted: 04.02.2013 - 14:28  ·  #3
Hi Rolf.
Yes, exactly so on all counts, if I understand what you are saying correctly. 'byteType' I take to mean a structure 255 bytes or fewer in size, and 'wordType' means a structure bigger than this.
Yes, it is purely visual, and the resultant assembler code will be identical to now.
But easier to read (and write!) code is good.
Re: sizeof
Posted: 05.02.2013 - 14:54  ·  #4
sorry, I could not implement this for some reasons.
MySQL Queries: 15 · Cache Hits: 14   79   93 · Page-Gen-Time: 0.022637s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
