DHCP-Server im (X)Mega?
Posted: 23.04.2017 - 20:43  ·  #1
Hallo @ all,
ich bin jetzt nicht der Netzwerkfachmann was den AVRCo betrifft, aber ...... Ist es möglich in einem (X)Mega einen DHCP-Server unter zu bekommen? Was braucht es dazu? Ist das kompliziert?
Was ich möchte: Ich habe eine Client-Client(Atmel)-Verbindung (Crossover) und ein Gerät fragt nach einer IP-Adresse. Es soll immer die gleiche IP heraus gegeben werden (10.1xx.x.1), so daß der (X)Mega (10.1xx.x.2) immer über die gleiche IP mit dem Gerät kommunizieren kann. Geht das?
.....ist nur mal eine unausgereifte Idee für eine Schaltung ;)
Re: DHCP-Server im (X)Mega?
Posted: 24.04.2017 - 14:45  ·  #2
Are you using a secondary chip such as a WizNET chip on the XMEGA? With such a chip it is not too difficult, I think.How much DHCP do you know? If you know how to ask is should be relatively easy to work out how to reply.
Posted: 13.05.2017 - 22:11  ·  #3
currently it is just an idea. Do you know how to print over a network connection? The connected device is a printer ;). Always the same type, but different devices. A special printer driver is not required.
Greeting
Posted: 15.05.2017 - 15:22  ·  #4
And you want your board to give the printer an IP address when it uses DHCP, is that right?
I wrote my own DHCP client usung the W5500 chip, and a server would not be too hard using the same technology, but it would be a DHCP server for all devices - it could not really distinguish between products. So if you connected, say a PC on the same network, it would offer its services to that too. That is just the way DHCP works.
I am not really clear on what you are trying to achieve, and in particular what other devices (if any) might be on this network.
Posted: 15.05.2017 - 15:34  ·  #5
Yes. A device is plugged in and receives always the same address from the DHCP server.
And there is always only one device that is connected.
This will be a test device for printers.
Posted: 15.05.2017 - 15:55  ·  #6
Ah OK. Are you happy to use the WizNET chip?
Posted: 15.05.2017 - 17:13  ·  #7
I can use any chip ;) .... at the moment this is theoretical
Posted: 16.05.2017 - 17:57  ·  #8
Then it should not be difficult :-)
MySQL Queries: 15 · Cache Hits: 13   134   147 · Page-Gen-Time: 0.031335s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
