FloatToStr(f:n:n) problem
allan offline
Subject: FloatToStr(f:n:n) problem  -  Posted: 04.10.2017 - 16:50   -
With new compiler (5.09.18) any attempt to convert float to string causes crash!
This does not work any more, even in simulator:
Float1 := 0.1001;
Float2 := 2.0002;
st := FloatToStr(Float1:6:4) + ' ' + FloatToStr(Float2:6:4);
Gunter offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 04.10.2017 - 23:20   -
Albert Einstein
Donald J. Trump on Twitter
allan offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 05.10.2017 - 13:04   -
OK, understood, but this is so easy to reproduce, just copy-paste these 3 lines and try.
Something bad happened to floating point numbers while I did not update (since 2012).
program avrprommer;
{ $W+ Warnings}            {Warnings off}
Device = mega64, VCC=3.3;
Import SysTick, WatchDog;
From System Import  Float;
        ProcClock   = 6000000;
        SysTick     = 10;            {msec}
        StackSize   = $0040, iData;
        FrameSize   = $0040, iData;
        WatchDog       = msec2000;
{$EEPROM}
Structconst
        st             : string[16];
        Float1, Float2 : float;
  // ----- DEBUG  ----
  Float1 := 0.1001;
  Float2 := 2.0002;
end avrprommer.
Gunter offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 05.10.2017 - 14:33   -
Hi.
I found no problem with 5.09.18
Albert Einstein
rh offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 05.10.2017 - 15:18   -
Allan, Gunter,
I also checked this example
Henry Ford
allan offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 05.10.2017 - 17:37   -
I see - if you just 'Make' it works, but 'Make & Optimize' was what I did...
So it must be optimizer related problem.
Gunter offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 05.10.2017 - 17:53   -
yes you are right !
Optimize creates an endless loop.
Merlin ?
Edit:
the problem is the optimisation of the FloatToStr function !
even "st := FloatToStr (1);" creates a loop.
Albert Einstein
This post has been edited 2-times. Last edit: 05.10.2017 - 18:25 by Gunter.
rh offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 05.10.2017 - 18:56   -
Hello Allan,
without complete environment and other infos we can't
evaluate such problems.
As always:
doesn't work ... doesn't help
Henry Ford
Merlin offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 05.10.2017 - 21:21   -
I will investigate.
:magic:
Software is a black art.
Merlin offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 06.10.2017 - 10:00   -
@Allan As a quick fix while I investigate further, if you add the following line near the top of your code it will disable the latest optimization while I investigate further
{$OPTI NO_OPT_TST}
:magic:
allan offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 06.10.2017 - 11:34   -
@Merlin, thanks!
It solves the actual problem I had with real project where comparing floating point numbers gave random results. This FloatToStr was only needed for debugging and also was easy to reproduce!
Merlin offline
Subject: Re: FloatToStr(f:n:n) problem  -  Posted: 06.10.2017 - 13:30   -
Hi Allan.
I have now fixed the bug. Either you can wait for next update or if you let me know your e-mail via pm I will send you the fix directly.
:magic:
Delete cookies of this forum  •  FAQ / Help  •  Team page  •  Imprint   |  Local time: 20.02.2018 - 02:27
