SerOut
Probleme beim senden
Test123
Re: SerOut
Gepostet: 12.12.2011 - 14:45 Uhr  ·  #9
The module needs 9600 baud, no parity, 8 databits and one stopbit.
I changed the baudrate again. This time I used a baudrate like 9200 and my error code changed from these weird numbers to
! c y
This is almost correct. If the "c" and "y" would be capital letters, then it would work.
So I thought of changing the baudrate to other numbers, but I cannot get rid of the error message.
The module still reads small letters instead of capital letters.
Re: SerOut
Gepostet: 12.12.2011 - 15:28 Uhr  ·  #10
Try to connect your board to a Terminal program and look for your write message.
If all is ok, then try to send your command from the Terminal program to the module.
I think one of them have a baudrate with too high errors.
Re: SerOut
Gepostet: 12.12.2011 - 15:29 Uhr  ·  #11
Are you using 232 or 485 or something else? It looks to me as if you may be letting lines drift. Do you have 0V connected properly and are there weak pull-ups on the data lines (weak pull-aparts for 485) to ensure that data lines are held in the correct idle state?
Test123
Re: SerOut
Gepostet: 16.12.2011 - 16:21 Uhr  ·  #12
the communication works now.
Today I worked on it again and I replaced the MAX202 with another one. And now I can receive and send the data.
Thank you guys for helping.
MySQL Queries: 8 · Cache Hits: 14   79   93 · Page-Gen-Time: 0.012327s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
