X10 RF Protocol Decode - How to???
nwrightson
Herkunft: Newcastle
Homepage: nweha.homeserver.c…
Re: X10 RF Protocol Decode - How to???
Gepostet: 05.04.2012 - 12:25 Uhr  ·  #9
Merlin,
Anything you have would be great.
Thanks for the links Avra.
Neil.
Mr Crusty
Gepostet: 05.04.2012 - 12:39 Uhr  ·  #10
Merlin,
If possible can you copy me into the code you send to Neil? I have a similar problem, which this may help.
Does anyone know what the Honeywell CM Zone (domestic central heating wireless control system) uses as wireless protocol?
Crusty
Gepostet: 05.04.2012 - 14:21 Uhr  ·  #11
Since a few people asked for it...
  DebounceLogic : array [0..15] of byte = (%0000, %0010, %0100, %0110, %0000, %0010, %0100, %1110,
                                      %0000, %1010, %1100, %1110, %1000, %1010, %1100, %1110);
  // 3 key debounce array.
  UnDebounced : byte = 0; // un-debounced input bit location
  Debounced   : byte = 3; // debounced bit location
  Inputs : array [0..17] of byte; // debounce control
function fDebounce( Location : byte; Value : boolean ) : boolean;
  Setbit( Inputs[ Location ], Undebounced, Value );
  Inputs[ Location ] := DebounceLogic[ Inputs[ Location ]];
  return( bit( Inputs[ Location ], debounced ));
It is meant to be quite fast. If you only have 1 input, obviously you don't need the array 'Inputs' which will make things run faster. The output only changes state when 3 successive input have the same value.
Gepostet: 05.04.2012 - 15:45 Uhr  ·  #12
Mr Crusty
Gepostet: 05.04.2012 - 17:09 Uhr  ·  #13
Hi Avra,
Many thanks for the links,
I have the HR80 radiator thermostatic valves, which are networked by radio.
I suspect that there is some commonality between the HR20 and HR80 valves, so i can start my hack from this point.
The valves communicate with an HC60NG boiler control unit and as I have a spare of this I may start my attack at this point.
My aim in the first instance, is to be able to display which radiator is calling for demand.
Best
Crusty
Gepostet: 05.04.2012 - 23:46 Uhr  ·  #14
Mr Crusty
Gepostet: 06.04.2012 - 13:11 Uhr  ·  #15
Avra,
Again many thanks, I am always amazed by the way you can find links.
Best
Crusty
MySQL Queries: 15 · Cache Hits: 14   114   128 · Page-Gen-Time: 0.023685s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
