workaround for a pointer to bit
  • Seite 2 von 3
Re: workaround for a pointer to bit
Gepostet: 24.06.2014 - 00:33 Uhr  ·  #9
In my case board already has defined pins like this:
  DI_1_TAGNUM: word = 14;
  DI_2_TAGNUM: word = 15;
{$PDATA}
  DI_1[@PinA, 0]: bit;
  DI_2[@PinA, 1]: bit;
and since AvrCo doesn't have a bit pointer I will not be able to simply loop through an array of records like in my first post, but to manually code something like this:
  case TagNum of
      DI_1_TAGNUM:
         if Command = cmdRead  then Result := DI_1; endif;
         if Command = cmdWrite then DI_1 := NewValue; endif;|
      DI_2_TAGNUM:
         if Command = cmdRead  then Result := DI_2; endif;
         if Command = cmdWrite then DI_2 := NewValue; endif;|
  endcase;
Of course this is over simplified example of what I have, but you can see from it that using bit setting and getting functions would complicate things, make code less readable, and make me maintain bits pin list at two places: var section and code section.
Gepostet: 24.06.2014 - 10:23 Uhr  ·  #10
Hi Avra.
Here is an adaptation of your original suggestion that shows what I had in mind.
  PByte = pointer to byte;
  p = pointer;
  TTagStruct = record
    No : word;
    Tag: PByte;
    Offset : byte;
{$PDATA}
const // or structconst
  MX: array[1..2] of TTagStruct = ((No: 8; Tag: @PinA; Offset: 0),
                                   (No: 23; Tag: @PinA; Offset: 1));
then
with MX[1] do
  if Bit(Tag^, Offset),  then
    WriteLn(Serout, 'that bit is on');
    WriteLn(Serout, 'that bit is off');
endwith;
I don't know if it will work but...
Gepostet: 24.06.2014 - 10:37 Uhr  ·  #11
some suggestions to handle port bits ...
Example 1: not working, compiler error, why?
    MYBIT_REG : word = @PINA;
    MYBIT_NR : byte = 4;
    MYBIT[MYBIT_REG,MYBIT_NR] : bit; // compile error: address $0608 is below iDataStart $2000
    // accessing the BIT //
    MYBIT := 1;
end.
Example2: not working, Compiler error, why?
    MYBIT_REG : pointer = @PINA;
    MYBIT[MYBIT_REG,MYBIT_NR] : bit; // compile error: $0608 is below iDataStart $2000
    MYBIT := 1;
end.
Example3: not working, compiler error, why?
alias
    MYBIT_REG = PINA;
    MYBIT[@MYBIT_REG,MYBIT_NR] : bit; // compile error: Identifier expected
    MYBIT := 1;
end.
Example4: working
// a variable for register + const for bitnumber
    MYBIT_REG[@PINA] : byte;
    // accessing the bit //
    MYBIT := 1;
    // or //
    MYBIT_REG.MYBIT_NR := 1;
end.
Example5:
// an alias for the register + const for bitnumber
alias
    MYBIT_REG = PINA;
    // // it is not possible to define a bit with an alias //
    // MYBIT[@MYBIT_REG,MYBIT_NR] : bit; // compiler error: Identifier expected
end.
Example6:
// an alias for the register + alias for bitnumber
    BIT4 : byte = 4; // workaround for compiler error
alias
    MYBIT_REG = PINA;
    //BITNR = 4; // compiler error: Identifier expected
    MYBIT_NR = BIT4;
end.
Gepostet: 24.06.2014 - 11:37 Uhr  ·  #12
    MYBIT := 1;
end.
because it is in the wrong data space.
you need
{$PDATA}
    MYBIT := 1;
end.
Ditto for example 2.
Gepostet: 24.06.2014 - 12:34 Uhr  ·  #13
Hello merlin,
thank you very much. I was so confused about example 1 and 2.
Example 3 with alias Statement still does not work, should it?
Gepostet: 24.06.2014 - 13:13 Uhr  ·  #14
Hello Thomas.
In my opinion, yes 3 should work, but I can understand why it doesn't. Aliases are relatively new, and bits are so special, it is perhaps no surprise that it is not implemented yet.
Gepostet: 24.06.2014 - 14:23 Uhr  ·  #15
Zitat geschrieben von Merlin
with MX[1] do
endwith;
:-k
Your plastic example made me think again and it seams that Offsets can be constants so that with little code adaptation bit numbers would not have to be maintained in two separate lists, and I can still iterate through an array.
Merlin, thanks a lot for your persistence and help! :gut:
:occasion5:
Gepostet: 26.06.2014 - 13:03 Uhr  ·  #16
Above construction works with MX[] stored in structconst section. With MX[] stored in const section, I had to adjust a little:
  p: pointer;
with MX[1] do
  p := Tag;                   // workaround to avoid compile error with MX[] in const
  if Bit(p^, Offset),  then   // workaround to avoid compile error with MX[] in const
endwith;
I am publishing this info in case someone else bumps into the same problem.
Thanks again,
  • Seite 2 von 3
MySQL Queries: 15 · Cache Hits: 14   126   140 · Page-Gen-Time: 0.022907s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
