[BUG REPORT OPTIMISER]
wrong address calculaction
Re: [BUG REPORT OPTIMISER]
Gepostet: 25.01.2016 - 22:19 Uhr  ·  #9
@all
The problems are a little more subtle than it would at first appear. The particular implementation has some fairly obvious solutions, as you say with ADIW, but that would be a totally new optimisation. This is actually a manifestation of a deeper problem, which I need to think about first. My main concern is that fixing this problem may introduce new ones.
Once I have solved this problem to my satisfaction I will look at implementing the ADW/SBIW, probably as a separate release.
Gepostet: 25.01.2016 - 22:35 Uhr  ·  #10
or you use
LDI _ACCA, xx
STS Z, _ACCA
LDI _ACCA, yy
STD Z+11, _ACCA
LDI _ACCA, ...
STD Z+22, ...
which will use only 2 cycles for adding and storing instead of 3 for adding separately and storing ... it also will use smaller amount of ROM,
but the displacement is only +/-63 and the Z-Register is not changed ... the flags are not changed too
all depends on the number and size of displacements to add ... so you must decide what to do ...
Gepostet: 26.01.2016 - 15:01 Uhr  ·  #11
an easy solution which the Opti should be able to handle is this:
original ASM
  LDI       _ACCCLO, optimizerAddressBug.btnArray AND 0FFh
  LDI       _ACCCHI, optimizerAddressBug.btnArray SHRB 8
  ADIW      _ACCCLO, 0000Bh
  LDI       _ACCA, 002h
  ST        Z+, _ACCA
Optimiser
  LDI       _ACCCLO, optimizerAddressBug.btnArray+11 AND 0FFh
  LDI       _ACCCHI, optimizerAddressBug.btnArray+11 SHRB 8
  LDI       _ACCA, 002h
  ST        Z+, _ACCA
The offset, in this case 11/$0B, is directly added into the Z-pointer load
Gepostet: 26.01.2016 - 22:20 Uhr  ·  #12
@All
I sincerely thank you all for your input, I truly do, but the problem is not the one that you imagine.
The problem is that the optimiser interprets addresses wrongly, and therefore incorrectly optimises. Sadly, the solutions that you propose only mask the problem, not solve it. Now the problem is correctly solved, the original optimisation is almost as efficient your proposed solutions, and so it is not worth adding a new optimisation, especially as it only solves a very limited problem that would not be used in practice (a for loop would be used instead typically).
Thomas, do you need me to e-mail you with the fix? If so, please let me know your e-mail by pm.
Thank you all again.
@Rolf: Your last suggestion is exactly what the optimiser does. The problem is that a later optimisation removes what it sees as superfluous lines, which are mostly correct, but not quite all.
Gepostet: 27.01.2016 - 11:59 Uhr  ·  #13
Hello again,
@all: Thanks for your Input, too.
@Merlin: Not neccessary, I am waiting for an official update.
MySQL Queries: 8 · Cache Hits: 14   94   108 · Page-Gen-Time: 0.013572s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
