Cha[@PortD,0] : bit; als Array?
  • Seite 2 von 3
Re: Cha[@PortD,0] : bit; als Array?
Gepostet: 06.03.2018 - 11:45 Uhr  ·  #9
Nicht schön, aber es funktioniert :)
Procedure ReadStatus;        // Einlesen und aufbereiten der C&RStatus-Variablen
  Var D1, D2, Counter : Byte;
    D1:=PinB;                // --> R8 C8 R7 C7 R6 C6 R5 C5
    D2:=PinF;                // --> C4 R4 C3 R3 C2 R2 C1 R1
    SetBit(CStatus.7,D1.1);  // CStatus --> Charge Slot 8,7,6,5,4,3,2,1
    SetBit(CStatus.6,D1.3);
    SetBit(CStatus.5,D1.5);
    SetBit(CStatus.4,D1.7);
    SetBit(CStatus.3,D2.0);
    SetBit(CStatus.2,D2.2);
    SetBit(CStatus.1,D2.4);
    SetBit(CStatus.0,D2.6);
    SetBit(RStatus.7,D1.0);  // RStatus --> Ready Slot 8,7,6,5,4,3,2,1
    SetBit(RStatus.6,D1.2);
    SetBit(RStatus.5,D1.4);
    SetBit(RStatus.4,D1.6);
    SetBit(RStatus.3,D2.1);
    SetBit(RStatus.2,D2.3);
    SetBit(RStatus.1,D2.5);
    SetBit(RStatus.0,D2.7);
  End ReadStatus;
Dauert ca. 32µs auf einem XMega256 @ 32 MHz.
Gepostet: 06.03.2018 - 18:03 Uhr  ·  #10
Shame the bits of RStatus and CStatus are that way round wrt to port pins. Were they the other way round you could have used
    CStatus := ( D1 and %10101010) or (D2 and %01010101);
    RStatus := ( D1 and %01010101) or (D2 and %10101010);
The following uses a lookup table to reverse the bits.
  cReverse : array[0..15] of byte = (%0000, %1000, %0100, %1100,
                                     %0010, %1010, %0110, %1110,
                                     %0001, %1001, %0101, %1101,
                                     %0011, %1011, %0111, %1111);
function ReverseByte( pByte : byte ) : byte;
  Return( (cReverse[ pByte and $0F ] shl 4) or (cReverse[ pByte shr 4 ]) );
Procedure ReadStatus; // read in and prepare the C & R status variables
  Var D1, D2, Counter: Byte;
    D1: = PinB; // -> R8 C8 R7 C7 R6 C6 R5 C5
    D2: = PinF; // -> C4 R4 C3 R3 C2 R2 C1 R1
    CStatus := ReverseByte(( D1 and %10101010) or (D2 and %01010101));
    RStatus := ReverseByte(( D1 and %01010101) or (D2 and %10101010));
  End ReadStatus;
Gepostet: 06.03.2018 - 19:46 Uhr  ·  #11
thanks i will test it :). Because the circuit does not yet exist (i am waiting for a component delivery), this is a good way to play with the simulator ;).
Gepostet: 07.03.2018 - 07:23 Uhr  ·  #12
Hello merlin,
it doesn't work. Look at the Picture.
Gepostet: 07.03.2018 - 09:44 Uhr  ·  #13
Yes, of course. Sorry.
Gepostet: 07.03.2018 - 10:01 Uhr  ·  #14
The Picture was wrong - sorry. Now its ok.
I test at this Moment this:
RStatus:= (D1 and %10000000) or ((D1 and %00100000) shl 1) or
         ((D1 and %00001000) shl 2) or ((D1 and %00000010) shl 3) or
         ((D2 and %01000000) shr 3)  or ((D2 and %00010000) shr 2) or
         ((D2 and %00000100) shr 1) or (D2 and %00000001);
[Edit]It works :) ... 2.98µs
Procedure ReadStatus2;       // read in and prepare the C & R status variables
  Var D1, D2 : Byte;
    D1:= PinB;               // -> R8 C8 R7 C7 R6 C6 R5 C5
    D2:= PinF;               // -> C4 R4 C3 R3 C2 R2 C1 R1
    RStatus:=$00;
    CStatus:=$00;
    CStatus:=((D1 and %01000000) shl 1) or ((D1 and %00010000) shl 2) or
             ((D1 and %00000100) shl 3) or ((D1 and %00000001) shl 4) or
             ((D2 and %10000000) shr 4) or ((D2 and %00100000) shr 3) or
             ((D2 and %00001000) shr 2) or ((D2 and %00000010) shr 1);
  End ReadStatus2;
Gepostet: 07.03.2018 - 10:21 Uhr  ·  #15
Minor improvement - you don't need to set your values to zero, they are completely defined anyway.
Gepostet: 10.03.2018 - 22:41 Uhr  ·  #16
Das alles wird ein Akkutester für gebrauchte LiIon-Zellen der Bauform 18650.
I use Litokala Lii-500 for charging and real capacity measurement of NiCD, NiMh and LiIon. With 18650 it even doubles as a nice battery bank. After buying it I found that when chinese write 3000mAh they actually mean 200mAh.
http://lygte-info.dk/review/Re…%20UK.html
  • Seite 2 von 3
MySQL Queries: 8 · Cache Hits: 14   131   145 · Page-Gen-Time: 0.015292s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
