Receiving data via TINA
  • Seite 3 von 3
Re: Receiving data via TINA
Gepostet: 03.12.2012 - 20:47 Uhr  ·  #17
Hello Andreas,
if you use the ++ option the pointer is incremented (manipulated). If you need the last byte in your buffer you can do this:
because the bufferpointer always points into a buffer which your application must provide you can directly access the last byte of your buffer with
eot:= myBuffer[PacketRecInfo.RecLen-1]; // array access last reveived byte (eot)
btw.
The TINA uses a blocked transfer. It accepts the next Rx package only after the socket is re-enabled. There is no pipe or something else.
AV
Gepostet: 04.12.2012 - 12:14 Uhr  ·  #18
Thanks again for your answers (-:
The buffer reading still causes trouble.
I did it as you wrote, but get a compiler error.
The compiler doesn't like the ++ and wants to have a semicolon after bufferPtr^.
byte0 := pRecInfo.bufferPtr^++;
... Right now I found a solution.
I wrote it like this:
byte0 := pRecInfo.bufferPtr^;
pRecInfo.bufferPtr++;
Maybe it's useful for somebody.
AV
Gepostet: 04.12.2012 - 12:31 Uhr  ·  #19
IMPORTANT
My code of several posts contains an error!
The variable BuffPtr of the record pRecInfo was written in the wrong way.
You have to add "er" to the variable BufferPtr.
I wanted to correct my code snippets, but unfortunately I can't edit my posts anymore. (There is a time out)
Gepostet: 04.12.2012 - 15:33 Uhr  ·  #20
Hi AV.
You can only autoincrement a direct pointer, not an indirect one (because of the offset calculations required in the resultant assembler, I think). However you can convert your indirect pointer to a direct one and then carry out your calculations like this
procedure Test( var pRecInfo : tRecInfo );
  iPtr : pointer to byte;
  byte0 : byte;
  iPtr := pRecInfo.bufferPtr;
  byte0 := iPtr^++;
  pRecInfo.bufferPtr := iPtr;
Obviously not worth it unless you are doing several successive calculations or within a loop.
Gepostet: 04.12.2012 - 19:41 Uhr  ·  #21
or you can directly access your local buffer with:
  myBuffer   : array[0..xx] of byte;
  ptr : pointer;
  ptr:= @myBuffer;
  byte0:= ptr^++;
  byte1:= ptr^++;
  ptr:= @myBuffer+pRecInfo.RecLen;
  eot:= ptr^;
  • Seite 3 von 3
MySQL Queries: 8 · Cache Hits: 14   94   108 · Page-Gen-Time: 0.015028s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
