Fehlermeldung Programmer
  • Seite 4 von 4
Re: Fehlermeldung Programmer
Gepostet: 16.11.2010 - 19:32 Uhr  ·  #25
do you have the Windows sounds active ?
(do you hear this "Ding-Dong" when dis-/connecting the programmer?)
A weak point are the USB connectors at the programmers.
Typical indications are several "Ding-Dongs" when moving the attached
cable at the programmer side slightly up and down.
This can be the reason for a "works sometimes" problem.
I assume you tried already another cable?
Jest
Gepostet: 17.11.2010 - 14:30 Uhr  ·  #26
Hello Gunter,
yes, there is ding-dong and I changed cable.
But, it happened something strange. All at once, system recognizes ISP and I can compile - at least one or two times - then I must do disconnect/connect story.
It is annoying but at least I can compile... :D
Hope that we will solve also this. Best regards,
Andrej
Gepostet: 17.11.2010 - 21:14 Uhr  ·  #27
Hi Andrej,
I assume a problem with your PC/Win/USB/USB-Hub(?).
Hope you can work until your coworker is back.
You should swap both programmers for a day or so.
  • Seite 4 von 4
MySQL Queries: 15 · Cache Hits: 14   57   71 · Page-Gen-Time: 0.020377s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
