ModBus RTU mit XMega
  • Page 2 of 2
Homepage: pvs-deck.de
Re: ModBus RTU mit XMega
Posted: 29.06.2012 - 14:08  ·  #9
Quote by Avra
XMEGA MODBUS ASCII driver is working. Moving to XMEGA MODBUS RTU driver.
Hello Avra,
nice :) How can i get the Driver? Update AVRco?
Bye
Posted: 01.07.2012 - 23:25  ·  #10
It's now officially in 5.04.01 version. Just update your AvrCo.
Posted: 22.07.2012 - 13:25  ·  #11
Quote by Avra
Hello Avra.
Sorry, but it don't work :(
The only change with the xMega_ModBusRTU and my Test-Programm is the CPU (i Use XMEGA256A3), Switchport and the BeepPort. I don't use this Options.
Here is my Test-Code (From the Demo with some little Changes):
program TestModBusXMega;
Device = XMega256A3, VCC=3.3;
//  Override_Fuses;
  NoteBook   = A;
  COMport    = USB;
  LockBits0 = [];
  FuseBits0  = [];
  FuseBits1  = [];
  FuseBits2  = [];
Import SysTick, SerPortC0, ModBus;
From System Import Processes, Longword, Float, Random;
  //>> CPU=32MHz, PeripherX4=32MHz, PeripherX2=32MHz
  OSCtype        = int32MHz,
                   PLLmul=4,
                   prescB=1,
                   prescC=1;
//                   overdrive;
  SysTick        = 10;           // msec
  Scheduler      = iData;
                   // if you do not have rx/tx buffer large enough, some messages may be lost
  SerPortC0      = 19200, Databit8, parEven, Stop1;
                   // size of this buffer mainly depends on MODBUS CAPACITY
                   // if you expect very large messages increase this up to 254
                   // (if this port is used with modbus)
  RxBufferC0     = 10, iData; // recommended 255, but may be lower (danger: minimum is max message length in bytes)
  TxBufferC0     = 100, iData; // recommended 255, but may be lower (danger: minimum is max message length in bytes)
                   // Choose port and pin for RS485 line driver
  // SerCtrlC0      = PortF, 0, Positive;
                   // port used, capacity in words, memory area, Framesize (must not exceed 240 bytes)
  ModBus         = SerPortC0, 40, iData, 240;
  ModBusMode     = RTU {ASCII}, Timer_C1;
//  SwitchPort1    = PinD, $00;
//  PolarityP1     = $00;                  // polarity
//  SwitchPort2    = PinE, $00;
//  PolarityP2     = $FF;                  // polarity
//  BeepPort       = PortR, 0;
//  SysLEDblink    = mSec300;           {10..1000 msec}
//  SysLEDBlink0   = PortR, 1, low;     {LEDon = low level}
Uses ModBusServRTU;
  tVar_Flags    = (rw_job_is_started = 15);      // use the prefix "rw_" to define a coil = read/write
  tFlagsSet     = BitSet of tVar_Flags;
  tLights       = (Light1_on = 10, light2_on);   // without the prefix "rw_" this is a readonly discrete input
  tLightSet     = BitSet of tLights;
  FRamBase      : byte     = $50;
   ww               : word;
   SecTimer         : SysTimer;
   long_counter     : longword; // needed to calc scans_per_second
   // MAPPING //
   // Modbus protocol is not awared of type of data transfered. It can transfer only words and bits,
   // but we can map longs, floats, strings, and other stuff and then interprete transfered data.
   // You can see here how to map all kind of variables to data zone that deals only with words.
   // The same remapping logic must be implemented in master also (usually PC or PLC).
   // To conclude, naming mapped variables and using their natural type is the most wanted behavior.
   // All you have to do is read/write these mapped variables, and communication is transparent in a process!!!
   // We use the predefined types so that the E-LAB tool "ModBusTest" can handle it
   // and can build a printable list of ModBus types and corresponding addresses
   // These are the predefined types. Data direction seen from the master's (client) point of view
   // mb_Inp.. defines a read only type. mb_RdWr.. defines a read and write type.
   //   mb_InpB    = byte;               // !! always as couples
   //   mb_RdWrB   = byte;               // !! always as couples
   //   mb_InpW    = word;
   //   mb_RdWrW   = word;
   //   mb_InpI    = Integer;
   //   mb_RdWrI   = Integer;
   //   mb_InpW32  = longword;
   //   mb_RdWrW32 = longword;
   //   mb_InpI32  = longInt;
   //   mb_RdWrI32 = longInt;
   //   mb_InpF    = Float;
   //   mb_RdWrF   = Float;
   //   additional types are one-dimensional arrays of byte
   //   and bitsets. Bitsets are treated as Coils or DiscreteInputs, dependant of the name prefix "rw_"
   //   Booleans are not directly supported. They can be implemented as bytes, coils or discrete inputs
   // Using the switch below forces the compiler to build a readable parameter list.
   // The name "ModBuff" is mandatory !!
   // The argument is the filename.pmbl
   {$MODBUS MBsampleRTU}
   ModBuff[@ModDPR] : record                                        // word byte
                        counter1         : mb_InpW;                 // [00] 00..01
                        various_flags    : tFlagsSet;               // [01] 02..03 access individual bits (coils)
                        port_j           : mb_RdWrB;                // [02] 04     this is lo(ModDPR[2])
                        port_k           : mb_RdWrB;                // [02] 05     this is hi(ModDPR[2])
                        dummy_word0      : mb_RdWrW;                // [03] 06..07
                        scans_per_second : mb_InpW32;               // [04] 08..11 main loop executed in every second
                        String0          : array[0..3] of char;     // [06] 12..15 only multiple of 2 possible, always R/W
                        voltage1         : mb_InpF;                 // [08] 16..19 this is float(ModDPR[8], ModDPR[9])
                        counter2         : mb_InpW;                 // [10] 20..21
                        counter3         : mb_InpW;                 // [11] 22..23
                        lights           : tLightSet;               // [12] 24..25
                        inverted_byte    : mb_InpB;                 // [13] 26     this is lo(ModDPR[13])
                        dummy_byte0      : mb_InpB;                 // [13] 27     this is hi(ModDPR[13])
                        CompYear         : mb_InpW;                 // [14] 28..29
                        CompMonth        : mb_InpW;                 // [15] 30..31
                        CompDay          : mb_InpW;                 // [16] 32..33
                        CompHour         : mb_InpW;                 // [17] 34..35
                        CompMinute       : mb_InpW;                 // [18] 36..37
                        ProjBuild        : mb_InpW;                 // [19] 38..39
                        before_register_read_counter  : mb_InpW32;  // [20] 40..43 event counter
                        after_register_read_counter   : mb_InpW32;  // [22] 44..47 event counter
                        before_register_write_counter : mb_InpW32;  // [24] 48..51 event counter
                        after_register_write_counter  : mb_InpW32;  // [26] 52..55 event counter
                        before_coil_read_counter      : mb_InpW32;  // [28] 56..59 event counter
                        after_coil_read_counter       : mb_InpW32;  // [30] 60..63 event counter
                        before_coil_write_counter     : mb_InpW32;  // [32] 64..67 event counter
                        after_coil_write_counter      : mb_InpW32;  // [34] 68..71 event counter
                        byte_0           : mb_RdWrB;                // [36] 72     this is lo(ModDPR[36])
                        byte_1           : mb_RdWrB;                // [36] 73     this is hi(ModDPR[36])
   // testing with simple communication software without any additional tools: //
   // $01$04$00$00$00$01$31$CA - this will read 1 analog input register starting from number 0.
   // $01$04$00$00$00$28$F0$14 - this will read 40 analog input registers starting from number 0.
   // $01$05$00$1F$FF$00$BD$FC - this will write bit JobIsStarted to 1 (enable counting scans).
   // $01$05$00$1F$00$00$FC$0C - this will write bit JobIsStarted to 0 (disable scans count).
   // for more information, take a look at "MODBUS Application Protocol Specification 1.1"
procedure InitPorts;
procedure mb_BeforeRegisterRead(RegisterNumber: word);
  Inc(ModBuff.before_register_read_counter);
  // initial setup
  InitPorts;
  ModBuff.String0[0]:= 'a';
  ModBuff.String0[1]:= 'b';
  ModBuff.String0[2]:= 'c';
  ModBuff.String0[3]:= 'd';
  mb_SetBeforeRegisterRead(@mb_BeforeRegisterRead); // initialize user's event and enable it
  mb_SetModBusDevID(1);    // read device address from 5 DIP switches (1..32, nice for RS485)
  //SerBaud(9600);         // read baud rate from 2 DIP switches (9600, 19200, 38400, 57600)
  //SerParity(parEven);    // read parity from 2 DIP switches (Even, Odd, None)
  //SerDataBits(DataBit7); // read data bits from 1 DIP switch (7, 8)
  //SerStopBits(StopBit1); // read stop bits from 1 DIP switch (1, 2)
  { process init }
  //Priority(Main_Proc, 2);
  //Priority(mb_Communication, 2);
  //EnableInts;
  ModBuff.CompYear   := word(COMPILEYEAR);
  ModBuff.CompMonth  := word(COMPILEMONTH);
  ModBuff.CompDay    := word(COMPILEDAY);
  ModBuff.CompHour   := word(COMPILEHOUR);
  ModBuff.CompMinute := word(COMPILEMINUTE);
  ModBuff.ProjBuild  := PROJECTBUILD;
  Start_Processes($87);
 // BeepOutLH;
//  SysLEDflashAllOn;
  loop                       // start of scan (main loop)
    ModBuff.port_j:= 01;
    ModBuff.port_k:= 02;
    if rw_job_is_started in ModBuff.various_flags then  // if Master set this bit then he wants to know how many scans per second can we achieve
      Inc(long_counter);
    if isSysTimerZero(SecTimer) then
      SetSysTimer(SecTimer, 1000 div SysTick);       // 1 second
      // we will simulate reading values from some real devices here
      Inc(ModBuff.counter1);
      ModBuff.counter2 := ModBuff.counter1;
      ModBuff.counter3 := ModBuff.counter2 * 2;
      Dec(ModBuff.dummy_byte0);
      Toggle(ModBuff.lights, [light1_on]);
      SetBit(ModBuff.lights, [light2_on], Random > 13107); // chances are 4:1 that it will be lit (65535/5)
      ModBuff.inverted_byte := not ModBuff.inverted_byte;
      ModBuff.voltage1 := PI + float(Random) / 100000;  // randomize a little simulated voltage
        ModBuff.scans_per_second := long_counter;
        //BeepClick;
        ModBuff.scans_per_second := 0;
      long_counter := 0;
      //BeepClick;
  endloop;                   // end of scan
end TestModBusXMega.
The "E-Lab ModBus Tester" beeb only if i start the Scan, the Tester sending the ModBus RTU-Programm to the Port, but the XMega dosen't send the Answer!
The SerPort from XMega work if i use the ReadLn and WriteLn.
Can anyone try the Demo with the XMEGA256A3 ?
My AVRco Version is V5.04.03
Bye
Posted: 22.07.2012 - 15:57  ·  #12
leider hat sich noch ein Problem mit dem XMega RTU ergeben. Wir sind dran. Sorry.
Posted: 22.07.2012 - 19:51  ·  #13
Quote by rh
Hallo rolf.
Ahhhh, ok ich habe das ganze jetzt mal mit Modbus-ASCII
getestet, damit läuft es ohne Probleme.
Aber ich brauche dringend das RTU, mit ASCII kann ich nicht viel anfangen, die Visualisierungssoftware und auch die Touchpanel die wir im Feld einsetzen, arbeiten alle mit RTU.
Geb mir bitte eine Rückinfo, wenn der Fehler beseitigt ist.
SL30
Neuling
Posted: 07.06.2018 - 20:48  ·  #14
Quote by pvs-deck
Quote by Avra
Hello Avra.
//  Override_Fuses;
  NoteBook   = A;
  COMport    = USB;
  LockBits0 = [];
  FuseBits0  = [];
  FuseBits1  = [];
  FuseBits2  = [];
  OSCtype        = int32MHz,
                   PLLmul=4,
                   prescB=1,
                   prescC=1;
//                   overdrive;
  Scheduler      = iData;
Uses ModBusServRTU;
   ww               : word;
   // MAPPING //
   //   mb_InpW    = word;
   //   mb_RdWrW   = word;
   //   mb_InpF    = Float;
  // initial setup
  InitPorts;
  { process init }
  //EnableInts;
 // BeepOutLH;
      Inc(long_counter);
        //BeepClick;
      long_counter := 0;
      //BeepClick;
Bye
I have the same problem though the version is 5.09.38 and the year is 2018
Posted: 10.06.2018 - 20:00  ·  #15
Quote by SL30
Sorry, i use at this time only Modbus RTU on the ATMEGA.
I want to test MODBUS RTU on the XMEGA384C3 in 2-3 month, at the moment i have no time to do this.
Posted: 19.06.2018 - 09:20  ·  #16
I have just received a PM from user SL30 that he has solved his problem. It was not a driver problem.
  • Page 2 of 2
MySQL Queries: 15 · Cache Hits: 14   133   147 · Page-Gen-Time: 0.028748s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
