SSD1306 DeviceGraphIOS
  • Page 1 of 3
Posted: 24.06.2015 - 16:30  ·  #1
Danke an Harry der mir dabei geholfen hat.
das einzige was ich noch nicht hinbekommen habe ist das ich $B0 LCD Adr vorher setzen muss
LCD_Adr:= $B0; // immer vor gDispRefresh setzen
gDispRefresh; // senden
program gOLed;
Device = mega32, VCC=5;
Import SysTick, LCDGraphic, I2Cport;
From System Import ;
From LCDGraphic Import CharSet;    {block CharSet, pixels}
  ProcClock      = 14745600;       {Hertz}
  LCDGraphic     = 128, 64, 8;        {x-pix, y-pix, accesswidth}
  GViewports     = 1, iData;          {logical ViewPorts, scalings}
  DefCharSet     = 'Graphchars.pchr'; {FileName}
  TGraphStr      = 21;                {Graphic Text String Length}
  LCDgraphMode   = column, iData;     // linear, column, readonly
  I2Cport        = PortB;
  I2Cdat         = 4;
  I2Cclk         = 3,0;
Const
SCREEN_HOR_SIZE : byte = 128;
SCREEN_VER_SIZE : byte = 64;
SSD1306_SETCONTRAST                      : byte = $81;
SSD1306_DISPLAYALLON_RESUME              : byte = $A4;
SSD1306_DISPLAYALLON                     : byte = $A5;
SSD1306_NORMALDISPLAY                    : byte = $A6;
SSD1306_INVERTDISPLAY                    : byte = $A7;
SSD1306_DISPLAYOFF                       : byte = $AE;
SSD1306_DISPLAYON                        : byte = $AF;
SSD1306_SETDISPLAYOFFSET                 : byte = $D3;
SSD1306_SETCOMPINS                       : byte = $DA;
SSD1306_SETVCOMDETECT                    : byte = $DB;
SSD1306_SETDISPLAYCLOCKDIV               : byte = $D5;
SSD1306_SETPRECHARGE                     : byte = $D9;
SSD1306_SETMULTIPLEX                     : byte = $A8;
SSD1306_SETLOWCOLUMN                     : byte = $00;
SSD1306_SETHIGHCOLUMN                    : byte = $10;
SSD1306_SETSTARTLINE                     : byte = $40;
SSD1306_MEMORYMODE                       : byte = $20;
SSD1306_COLUMNADDR                       : byte = $21;
SSD1306_PAGEADDR                         : byte = $22;
SSD1306_COMSCANINC                       : byte = $C0;
SSD1306_COMSCANDEC                       : byte = $C8;
SSD1306_SEGREMAP                         : byte = $A1;
SSD1306_CHARGEPUMP                       : byte = $8D;
SSD1306_EXTERNALVCC                      : byte = $1;
SSD1306_SWITCHCAPVCC                     : byte = $2;
  ii         :    word;
  LCD_Adr    :    byte;
procedure InitPorts;
  PortA := %00000111;
  DDRA  := %00000000;
  PortB := %00011000;
  DDRB  := %00011000;
  PortC := %00000011;
  DDRC  := %00000011;
  PortD := %00110000;
  DDRD  := %00110000;
end InitPorts;
//$80 = Command
//$C0 = ein Datenbyte
//$40 = kontinuierlich Datenbytes
//  Sende Command Oled
Procedure ssd1306_command(cmd1 : byte);
   I2Cout($3C,$80,cmd1);
end ssd1306_command;
// Sende Data Oled
Procedure ssd1306_data(cmd1 : byte);
   I2Cout($3C,$40,cmd1);
end ssd1306_data;
// Setze Oled Adresse
Procedure SetAddress(page, lowerAddr,  higherAddr : Byte);
   ssd1306_command(page);
   ssd1306_command(lowerAddr);
   ssd1306_command(higherAddr);
End SetAddress;
// // 0111100 = $3C   I2C Adresse
Procedure Init_OLED;
  if I2Cstat($3C) then
// Init sequence for 128x64 OLED module
    ssd1306_command(SSD1306_DISPLAYOFF);                    // 0xAE
    ssd1306_command(SSD1306_SETDISPLAYCLOCKDIV);            // 0xD5
    ssd1306_command($80);                                   // the suggested ratio 0x80
// Multiplex Ratio
    ssd1306_command(SSD1306_SETMULTIPLEX);                  // 0xA8
    ssd1306_command($3F);                                   // alt 3F
// Display Offset
    ssd1306_command(SSD1306_SETDISPLAYOFFSET);              // 0xD3
    ssd1306_command($0);                                    // no offset
//Display Startline
    ssd1306_command(SSD1306_SETSTARTLINE);                  // $40
// Set Charge Pump
    ssd1306_command(SSD1306_CHARGEPUMP);                    // 0x8D
    ssd1306_command($14);
// Re-map
    ssd1306_command(SSD1306_SEGREMAP);                      // A1
// COM Output Scan Direction
    ssd1306_command(SSD1306_COMSCANDEC);                    // C8
// COM Pins Hardware Configuration
    ssd1306_command(SSD1306_SETCOMPINS);                    // 0xDA
    ssd1306_command($12);
// Contrast Control Register
    ssd1306_command(SSD1306_SETCONTRAST);                   // 0x81 Contrast
    ssd1306_command($CF);
// Set Pre Charge Period
    ssd1306_command(SSD1306_SETPRECHARGE);                  // 0xd9
    ssd1306_command($F1);                                   // alt 22 // $22 - External, $F1 - Internal
// Set VCOMH Deselect level
    ssd1306_command(SSD1306_SETVCOMDETECT);                 // 0xDB
    ssd1306_command($40);                                   // $40 $20
// Display OFF
    ssd1306_command(SSD1306_DISPLAYALLON_RESUME);           // 0xA4
    ssd1306_command(SSD1306_NORMALDISPLAY);                 // 0xA6
//--turn on oled panel
    ssd1306_command(SSD1306_DISPLAYON);                     // 0xAF
end Init_OLED;
{$D-}
UserDevice GraphIOS(cmd : byte; arg : byte);
// cmd=0 bedeutet RAM-Adresse auf oben links stellen
// cmd=1 bedeutet Datenausgabe
  if cmd = 0 then
      SetAddress(LCD_Adr, $00, $10);
      ii:=0;
      If ii < 128  then
          ssd1306_data(arg);
          Inc(ii);
          if ii > 127 then
            inc(LCD_Adr);
            ii:= 0;
{$D+}
  InitPorts;
  mDelay(50);
  Init_OLED;
  mDelay(350);    // Muss rein sonst Display dunkel
   gClrScr(0);
   gDrawRect(0,0,127,63,$FF);
   gDrawString(10,30,2,2,TxtRot0,'Hello');
   gDrawString(10,50,1,1,TxtRot0,'hello !!!');
end gOLed.
Re: SSD1306 DeviceGraphIOS
Posted: 24.06.2015 - 16:45  ·  #2
das LCD_adr wird normalerweise als Const deklariert ..... das ist doch die I2C-Adresse ?
Const
LCD_adr : byte = $B0;
Posted: 24.06.2015 - 17:26  ·  #3
ne ne sorry das ist die erste Page Adresse, habe ich blöde gemacht.
Hätte PageAdr schreiben sollen.
PS. ich muss vorher immer die Var auf $B0 setzen.
ich weiß nicht wie man das anders machen könnte
Posted: 24.06.2015 - 17:36  ·  #4
der SSD1306 kann maximal 128x64 Pixel, also gehe ich davon aus, daß der am Ende einer Page automatisch in die nächste Page springt. Du kannst dir also die Adressierung der Pages (bis auf die erste) sparen. Also cmd=0 auf oben links springen und dann die 8x128Byte übertragen.
Das wird niemals ausgeführt ;) ..... doch wird es, ist aber unnötig. Laß es mal weg.
          if ii > 127 then
            inc(LCD_Adr);
            ii:= 0;
Posted: 24.06.2015 - 17:53  ·  #5
Harry wenn ich das raus nehme geht nichts mehr
Posted: 24.06.2015 - 18:26  ·  #6
@Harry, Frank,
so muss das gemacht werden:
  if cmd = 0 then
      LCD_Adr:= $B0;       // <<<<<<<<<<<<<<<<<<<
      ii:=0;
      If ii < 128  then
Dann kann man sich das weiter unten sparen!
Posted: 24.06.2015 - 19:36  ·  #7
Hallo Rolf, ne es geht nicht, schaue Code
auch wenn ich das wieder rein nehme gehts nicht
if ii > 127 then
inc(LCD_Adr);
ii:= 0;
{$D-}
  if cmd = 0 then
      LCD_Adr:= $B0;
      ii:=0;
      If ii < 128  then
          ssd1306_data(arg);
          Inc(ii);
          if ii > 127 then
            inc(LCD_Adr);
            ii:= 0;
{$D+}
Posted: 24.06.2015 - 19:53  ·  #8
mach mal
  SSD1306_Data(arg);
Wenn ich den Treiber richtig verstehe (und ich dachte das ist so :D) macht der beim Refresh 1x cmd=0 und sendet dann alle Daten in einem Rutsch mit cmd=1.
..... natürlich muß der SSD so konfiguriert sein, daß der bei den Daten autoincrementiert, d.h. daß er nachfolgende Daten automatisch in die nächste Display-Adresse schreibt.
  • Page 1 of 3
MySQL Queries: 8 · Cache Hits: 14   139   153 · Page-Gen-Time: 0.017162s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
