FAT16-Problem
Re: FAT16-Problem
Posted: 04.01.2019 - 14:21  ·  #17
There is only one line of code different between the working and non-working version, so somehow that must be causing the problem.
But as to how or why, I have no idea.
SYSTEM._DrawVerLineP:
                        LDD       _ACCB, Y+007h
                        LDD       _ACCA, Y+008h
                        LDD       _ACCALO, Y+005h
                        LDD       _ACCAHI, Y+006h
                        LDD       _ACCDLO, Y+003h
                        LDD       _ACCDHI, Y+004h
                        LDD       _ACCBLO, Y+001h
                        LDD       _ACCBHI, Y+002h
                        LDS       _ACCCLO, ViewPortPTR
                        LDS       _ACCCHI, ViewPortPTR+1
                        STD       Z+20, _ACCDLO
                        STD       Z+21, _ACCDHI
                        STD       Z+22, _ACCBLO
                        STD       Z+23, _ACCBHI
                        LDD       _ACCELO, Z+0
                        LDD       _ACCEHI, Z+1
                        CP        _ACCB, _ACCELO
                        CPC       _ACCA, _ACCEHI
                        BRMI      SYSTEM._L1759
                        LDD       _ACCELO, Z+4
                        LDD       _ACCEHI, Z+5
                        CP        _ACCELO, _ACCB
                        CPC       _ACCEHI, _ACCA
                        BRMI      SYSTEM._L1759
                        CP        _ACCBLO, _ACCALO
                        CPC       _ACCBHI, _ACCAHI
                        BREQ      SYSTEM._L1759
                        BRPL      SYSTEM._L1756
                        PUSH      _ACCALO
                        PUSH      _ACCAHI
                        MOV       _ACCALO, _ACCBLO
                        MOV       _ACCAHI, _ACCBHI
                        POP       _ACCBHI
                        POP       _ACCBLO
SYSTEM._L1756:
                        LDI       _ACCDHI, 080h
                        LDD       _ACCELO, Z+2
                        LDD       _ACCEHI, Z+3
                        CP        _ACCALO, _ACCELO
                        CPC       _ACCAHI, _ACCEHI
                        BRPL      SYSTEM._L1757
                        MOV       _ACCALO, _ACCELO
                        MOV       _ACCAHI, _ACCEHI
SYSTEM._L1757:
                        LDD       _ACCELO, Z+6
                        LDD       _ACCEHI, Z+7
                        CP        _ACCELO, _ACCBLO
                        CPC       _ACCEHI, _ACCBHI
                        BRPL      SYSTEM._L1758
                        MOV       _ACCBLO, _ACCELO
                        MOV       _ACCBHI, _ACCEHI
SYSTEM._L1758:
                        PUSH      _ACCB
                        PUSH      _ACCA
                        PUSH      _ACCALO
                        PUSH      _ACCAHI
                        PUSH      _ACCBLO
                        PUSH      _ACCBHI
                        PUSH      _ACCDHI
                        LDD       _ACCDLO, Y+0
                        AND       _ACCDLO, _ACCDHI
                        BREQ      SYSTEM._L1760
                        RCALL     SYSTEM._GraphDotW1
                        RJMP      SYSTEM._L1762
SYSTEM._L1760:
                        RCALL     SYSTEM._GraphDotW0
SYSTEM._L1762:
                        POP       _ACCDHI
                        LSR       _ACCDHI
                        BRNE      SYSTEM._L1761
                        LDI       _ACCDHI, 080h
SYSTEM._L1761:
                        POP       _ACCBHI
                        POP       _ACCBLO
                        POP       _ACCAHI
                        POP       _ACCALO
                        POP       _ACCA
                        POP       _ACCB
                        SUBI      _ACCALO, 0FFh
                        SBCI      _ACCAHI, 0FFh
                        CP        _ACCBLO, _ACCALO
with the next line FAT16 on PORTE works:
                        BRNE      SYSTEM._L1758
but with this line it doesn't
                        BRCC      SYSTEM._L1758
here is rest of routine
SYSTEM._L1759:
                        RET
Re: FAT16-Problem
Posted: 04.01.2019 - 15:13  ·  #18
strange! The problem isn't the FAT driver but the Graph driver??
Re: FAT16-Problem
Posted: 04.01.2019 - 15:22  ·  #19
dafür spricht evtl. auch die Tatsache, daß es mir bei rückgemeldete 0 Bytes frei und trotzdem geschriebenen Daten das Dateisystem zerhagelt. Die Directory-Einträge sind vorhanden, aber Dateien und Verzeichnisse können nicht geöffnet werden.
Falls du es noch nicht gesehen hast: du hast ne Mail von mir :)
Re: FAT16-Problem
Posted: 04.01.2019 - 16:16  ·  #20
Hi Rolf.
I cannot say what the problem is really. Just that the working and non-working versions differ by just one line and that line is in the graphics routines. It makes no sense to me, and why moving the disk to port D should make a difference makes no sense either.
Re: FAT16-Problem
Posted: 04.01.2019 - 17:11  ·  #21
an welchen Portpins ist das LCD bei dir angeschlossen?
Re: FAT16-Problem
Posted: 04.01.2019 - 17:28  ·  #22
@all,
ich verstehe das nicht!
Merlin findet nur eine Zeile Differenz und das im Graphtreiber !!!
Ich mache mich auf die Suche
Re: FAT16-Problem
Posted: 04.01.2019 - 17:32  ·  #23
Hardware-SPI Port C.
..... und das ist kein LCD ;). 8 MAX7219 kaskadiert. Siehe auch topic.php?t=3493
Re: FAT16-Problem
Posted: 05.01.2019 - 14:05  ·  #24
Ich hab jetzt noch Thorstens Idee ausprobiert, aber auch mit dem Soft_SPI für die SD-Karte geht es nicht.
- alle Processe vor F16_GetDiskFree gesperrt: keine Änderung
MySQL Queries: 15 · Cache Hits: 14   136   150 · Page-Gen-Time: 0.026014s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
