AVRco Service
Re: AVRco Service
Posted: 01.10.2021 - 14:09  ·  #89
I suggest that free AvrCo should upgrade to version 6 at some point in the near future. I know that Rolf has been conservative with version numbering, but this should be an justified exception to ease future reference as many things have been changed.
Re: AVRco Service
Posted: 01.10.2021 - 14:17  ·  #90
Thanks Avra. I do plan to do this as soon as things are stable, but I have to be careful. I have no plans to update the PED and so I have to fit in with its requirements. My task at the moment is to determine exactly what those requirements are...
Re: AVRco Service
Posted: 02.10.2021 - 10:57  ·  #91
I should have said
Quote
Not an unqualified success I am afraid.
The update downloads and installs, but the PED does see the not update as successful.
This is now resolved and the full update should update the PED successfully.
@Frank - I know you uninstalled the old version and installed the new. This will have disabled the updating function in the PED. The attached utility will re-establish the updating facility. This will need to be 'run as administrator' to work.
Filename: AVRcoVerUpdate.zip
Filesize: 870.74 KB
Title:
Download counter: 8
Re: AVRco Service
Posted: 02.10.2021 - 13:48  ·  #92
Hello Merlin, I will test it more closely.
Greetings Frank
Re: AVRco Service
Posted: 03.10.2021 - 01:27  ·  #93
Quote
but the PED does not see the update
this is the reason why rh did not understand and did not answer
:'( Gunter
Re: AVRco Service
Posted: 03.10.2021 - 19:38  ·  #94
Hello Merlin, I made a little tool to relieve you of a bit of work.
So you don't need to pass on FTP access data to someone else to do this work.
I think you have a Delphi version installed, so I'll give you the project and you can enter your own FTP data.
Or I'll make an ini file with in where you can enter the access data yourself.
After Connect, all files that are important for a version number are loaded and a copy is saved in the program directory.
Then you can change the version number and upload each individual file.
PS: I look in the file to find the version number faster. I'll go through everything again tomorrow and then you'll get the project.
Greetings Frank
Hallo Merlin, um dir ein bissel Arbeit abzunehmen habe ich ein kleines Tool gebastelt.
So brauchst du keine FTP Zugangsdaten weiter geben das jemand anders diese Arbeit macht.
Ich denke du hast auch eine Delphi Version Installiert daher gebe ich dir das Projekt und du kannst deine eigenen FTP Daten eintragen.
Oder ich mache noch eine ini Datei mit rein wo du selber die Zugangsdaten eintragen kannst.
Nach Connect werden alle Datein die für eine Versions Nummer wichtig sind geladen und eine Copy im Programm Verzeichnis gespeichert.
Danach kannst du die Versions Nummer ändern und jede einzelne Datei hoch laden.
PS: Ich suche in der Datei das ich schneller die Versions Nummer finde. Ich gehe morgen noch einmal alles durch und dann bekommst das Projekt.
AVRco Service
Filename: 1.jpg
Filesize: 261.38 KB
Title:
Download counter: 113
AVRco Service
Filename: 2.jpg
Filesize: 171.32 KB
Title:
Download counter: 114
AVRco Service
Filename: 3.jpg
Filesize: 107.28 KB
Title:
Re: AVRco Service
Posted: 03.10.2021 - 23:15  ·  #95
Thank you Frank.
Re: AVRco Service
Posted: 04.10.2021 - 13:00  ·  #96
Hello Merlin, I sent you my little tool via PM.
I have my access data for my ftp server in there
let it stand, here you can first test it yourself on my server.
Later you can enter your ftp data yourself under const.
I had to enter / httpdocs for a directory change, I don't know what your name is, you have to look it up yourself with your ftp program.
I hope I could help you a little.
Greetings Frank
Hallo Merlin, ich habe dir mein kleines Tool per PN zu gesendet.
Ich habe meine Zugangsdaten für meinen ftp Server drin
stehen laßen, hier kannst du erstmal selber über meinen Server testen.
Später kannst du dann deine ftp Daten unter const selber eintragen.
Ich musste /httpdocs bei einem Verzeichnis wechel angeben, wie das bei dir heißt weiß ich nicht, da musst du selber mit deinen ftp Programm nachschauen.
Ich hoffe ich konnte dir ein bissel helfen.
MySQL Queries: 17 · Cache Hits: 15   138   153 · Page-Gen-Time: 0.029517s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
