How useful is AVRco
polling your opinion
  • Page 5 of 5
Poll
How useful is AVRco
great tool
8 (72.73%)
very useful
3 (27.27%)
useful
0 (0%)
less useful
0 (0%)
don't know
0 (0%)
0 (0%)
Total votes:11
Re: How useful is AVRco
Posted: 29.09.2006 - 21:24  ·  #33
I will step again into phantasy domain, I hope you'll forgive me...
Stimuli files would really help, but let's try to imagine more radical approach to the problem. Some thoughts can be seen at this post from Rene http://www.e-lab.de/phpBB2/vie…ght=script, but the main idea is to open simulator for the rest of us. I can think of at least 2 nice ways of doing this:
1. Use something like www.paxscript.com, and open simulator for user scripting
2. or make COM object, or DLL, or whatever you like that we can interface from Delphi, VB, VC++, C#... Then we set properties, call methods, and get events, and program or visualize whatever we like. This way I could finally get values of digital or analog pins drawn in a time diagram, with resolution up to 1 instruction. I could then make an OPC server and use standard OPC clients do all the hard work for me automatically (trending, data archiving...). I could even programmatically trigger another AVR that can fire stimuli files on it's pins to simulate input to main AVR. We are all developers, and I am sure that we can think of many more practical benefits of this approach.
Stefan
Posted: 06.10.2006 - 17:36  ·  #34
ich hätte erstmal auch nur zwei weniger bedeutsame Vorschläge (Wünsche).
-eine vereinfachte Parameterübergabe an SysTimer Variablen z.B. mit Einheit 10s oder 20ms bes. bei größeren Zeiten vertippt man sich schnell und es fehlt ne Null, die Folge könnte ne lange Suchen sein...
-den RC5 Treiber mit nem 8Bit Timer zu stricken, damit man für einfachste Dinge wie z.B. eine kleine Fernbedienung auch einen von den kleinsten Tinys nehmen kann
Da kommt von mir bestimmt noch mehr solcher "Kleinigkeiten" (in unregelmäßigen Abständen) ob es für Rolf wirklich Kleinigkeiten sind...??? :oops:
Stefan
Posted: 06.10.2006 - 17:43  ·  #35
Hi Avra,
stimuli is only necessary with pure simulating. Better as any stimuli, which
is a tremendeous work to build one, is to use the ICE :ja:
Hi Stefan,
Punkt 1 ist schon implementiert. Compiler Manual Seite 108 SetSysTimerM
Punkt 2 lässt sich nicht ohne weiteres verwirklichen, da die Auflösung eines
8bit Timers bei unterschiedlichen CPU Clocks nicht ausreicht und RC5 sehr
timing kritisch ist.
Stefan
Posted: 06.10.2006 - 17:49  ·  #36
Quote by rh
Punkt2 lässt sich nicht ohne weiteres verwirklichen, da die Auflösung eines
Hi Rolf,
und wenn man den Treiber bei Verwendung eines 8-Bit Timers an bestimmte CPU Clocks bindet?
Posted: 06.10.2006 - 17:58  ·  #37
Hi Stefan,
ok, wäre mal einen Versuch wert, wenns weniger dringendes gibt :wecker:
Stefan
Posted: 06.10.2006 - 18:02  ·  #38
Quote by rh
Hi Rolf,
klar ist ja auch nur ein kleiner Vorschlag/Wunsch.... :roll:
Stefan
  • Page 5 of 5
MySQL Queries: 17 · Cache Hits: 14   96   110 · Page-Gen-Time: 0.025334s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
