Writeln and my own procedure
Re: Writeln and my own procedure
Gepostet: 16.07.2010 - 10:16 Uhr  ·  #9
Hi Cusko.
I suspect that your problem is that there is a WriteLn within your driver. I doubt if WriteLn is designed to be recursive in this way.
User written functions are able to be recursive because they use the frame for parameters and local variables, but internal procedures tend to use more direct and efficient mechanisms like passing parameters within registers. Normally that is not an issue but in this case it is.
Gepostet: 18.07.2010 - 01:19 Uhr  ·  #10
TelnetTXBuffer:= TelnetTXBuffer+Letter;
This is not very efficient. Just imagine how many bytes are copied every time until string becomes for example 200 characters long. It is better to put just single character and increment index. If you use string instead of an array then you can modify length before sending to ethernet.
Cusko
Gepostet: 19.07.2010 - 11:23 Uhr  ·  #11
Thanks guys,
I successfully get the right results. As suggested I used an array instead of a string. The right code:
  TelnetTXBuffer  : Array[ 0..99] of Byte;
  TxBufferIndex   : byte;
{$DEVICE}
procedure EthOut( Letter:char);
  TelnetTXBuffer[ TxBufferIndex]:= byte( Letter);
  inc( TxBufferIndex);
  if ( Letter = #10) or ( TxBufferIndex = 100) then
     TinaSendPacket( sTelnet, @TelnetTXBuffer, Word( TxBufferIndex));
     TxBufferIndex:= 0;
Again, Thanks for help.
Cusko
MySQL Queries: 14 · Cache Hits: 14   60   74 · Page-Gen-Time: 0.019026s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
