Parameter download error
Re: Parameter download error
Gepostet: 14.03.2014 - 11:59 Uhr  ·  #9
set the clock to 1 Mhz until you solved the issue !
jaxy92
Gepostet: 14.03.2014 - 14:02 Uhr  ·  #10
When i plug my CC1110, after the programmer, i got "wrong Device-ID : 00FF7F CC1110-F32 expected" (An other device-ID)
Gepostet: 14.03.2014 - 14:17 Uhr  ·  #11
please check ..\AVRprog\CC110-F32 .dsc
This is a editable file und must contain the correct signature of the Chipcon.
Compare this entry with the controller manual!
jaxy92
Gepostet: 14.03.2014 - 14:48 Uhr  ·  #12
In the CC1110-F32 file, it contains
[device]
device=CC1110-F32
DeviceID=$01
HLL=false
PageSize=1
clocks=3
clock1=16000000
clock2=26000000
clock3=32000000
[lockbitsWR0]
Adr=0
Mask=$1F
cmd=$FFFF
0=DBGLOCK
1=LSIZE0
2=LSIZE1
3=LSIZE2
4=BBLOCK
[lockbitsRD0]
Adr=0
Mask=$1F
cmd=$FFFF
0=DBGLOCK
1=LSIZE0
2=LSIZE1
3=LSIZE2
4=BBLOCK
[memory]
romtotstart=$0
romtotend=$7fff
SRAM=4
What is the controller manual?
Gepostet: 14.03.2014 - 15:06 Uhr  ·  #13
the Datasheet
http://www.ti.com/lit/gpn/cc1110f32
But in meantime I doubt whether the CC have such a feature.
I think "rh" (Rolf) must make this issue clear.
jaxy92
Gepostet: 14.03.2014 - 15:57 Uhr  ·  #14
In the ISP3.pdf, i found
"Wrong Device ID
a. The voltage of the target is too high or too low (see below)
b. Wrong device selected
c. Chip defective
It is possible that a device ID in the target is permanently destroyed, but the device works correct
If it is the correct CPU-type the programming can be continued.
All the above problems can also be a problem of a defective programmer. In many cases the Reset Pin is
loaded with Rs and/or Cs. In this case the activated Push-Pull Reset can help.
If a CPU shows a wrong device ID at programming, nevertheless one can continue with programming.
But it doesn't help me..
Gepostet: 14.03.2014 - 17:57 Uhr  ·  #15
did you remember that you need an adaptor when using die TI Pinout on your target?
MySQL Queries: 8 · Cache Hits: 14   124   138 · Page-Gen-Time: 0.013709s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
