Parameter download error
jaxy92
Gepostet: 13.03.2014 - 10:39 Uhr  ·  #1
Hi all,
Here my problem:
5 years ago, i used to progam my microcontroller with my an ISP3-USB "USB 2.0". It worked perfectly.
After that, i abandoned this programmer until now. I am working on it at this moment and I need him to work. First of all, I got the programmer not found but I solved it.
Now the problem is the "parameter download error". I searched in the forum for a solution but still not found it.
Can someone help me? It's very urgent.
Thanks!
Re: Parameter download error
Gepostet: 13.03.2014 - 11:55 Uhr  ·  #2
2 solutions:
- use the original cd dellivered with the programmer
- ship the ISP3 to E-LAB for a firmware upgrade (free of charge)
See also http://e-lab.de/pdf/Programmer-History_en.pdf Chapter 3!
jaxy92
Gepostet: 13.03.2014 - 15:39 Uhr  ·  #3
Hallo Gunter,
I found the old CD for the installation of AVR prog. Now it works!
Thank you a lot! The new software was not compatible with the old programmer ISP3.
Have a nice day. ;)
jaxy92
Gepostet: 14.03.2014 - 09:23 Uhr  ·  #4
Hallo all,
I have an other problem, i got the message "Wrong device ID : 00FF1F CC1100-F32 expected" and "Device protected".
Do you know where it can come from? I got 2 programmers ISP3 like that so I think it's not the problem.
Any ideas?
Gepostet: 14.03.2014 - 11:10 Uhr  ·  #5
usually you see something like
"wrong device ID 00000" and "00FF1F CC1100-F32 expected"
The first value is the read value. What is this at your side?
"Device protedted" means LockBits are set. You must first erase the chip.
jaxy92
Gepostet: 14.03.2014 - 11:17 Uhr  ·  #6
I did not connect anything after the ISP3-USB.
At my side, there is no first value read. I got only "Wrong device ID : 00FF1F CC1100-F32 expected".
I can't erase the device because he is protected. I have disable the LockBits set.
Gepostet: 14.03.2014 - 11:36 Uhr  ·  #7
sorry - I don't know the Chipcon. Maybe another user (Rolf?) has an idea.
Usually these are problems caused by
- programming clock selection too high
- wrong programming pins used
- bad or too long ribbon cable
- additional load connected to programming pins
jaxy92
Gepostet: 14.03.2014 - 11:52 Uhr  ·  #8
Okay, no problem, i'll try to solve the problem alone but it's gonna be complicated..
Before this problem appears, just after the "Parameter download error", it works perfectly, i passed to program my device etc.
The programming clock is at 16MHz or 32 MHz.
Wrong programming pins are correct, i have checked it.
I removed the ribbon cable and only let the USB connection between the programmer and the computer.
MySQL Queries: 15 · Cache Hits: 14   136   150 · Page-Gen-Time: 0.033983s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
