Problem with Disp7sPort
  • Seite 3 von 3
Re: Problem with Disp7sPort
Gepostet: 07.02.2015 - 15:24 Uhr  ·  #17
Hello Thomas,
on my mega644 works it, but only with DDRC:=%00001111; .
Insert it after EnableInts;
Greetings
Gepostet: 07.02.2015 - 15:59 Uhr  ·  #18
I tested something and I hope that I can explain it with my bad english:
If you are sending on a double-digit display a one-digit number, the driver sends only one digit. The contents of the first display is shifted to the second. even if two digits are defined. This applies to "write (DispOut, ByteToStr (i));"
With "write (DispOut, ByteToStr (i:2));" the driver sends always two digits.
3xcs
Gepostet: 07.02.2015 - 20:18 Uhr  ·  #19
Hello!! Many many thanks for all the info and all the help!!!!!!!! :) :) You have a very good english!!!!
I have tried it and it´s better....now the two displays lights :) But display two act a little strange. I will try to attach a file showing how it looks like.
The program i´m running in the film is this code...
program Disp7s;
{ $NOSHADOW}
{ $W+ Warnings} {Warnings off}
Device = mega168;
Import SysTick, Disp7sPort;
From System Import ;
ProcClock = 16000000; {Hertz}
SysTick = 10; {msec}
StackSize = $0020, iData;
FrameSize = $0020, iData;
Disp7sPort = PortC, nonmux;
DispDigits = 2, iData;
DispMode = shiftLeft;
{ Type Declarations }
{ Const Declarations }
{ Var Declarations }
i : byte;
{ functions }
{ Main Program }
DDRC:=%00001111;
mDelay(1000);
for i:=10 to 20 do
write (DispOut, ByteToStr(i:2));
mDelay(1000);
endfor;
end Disp7s.
Kindest regards
3xcs
Gepostet: 07.02.2015 - 20:42 Uhr  ·  #20
This is very strange! hmmm.....
If i declare some variables, like a string under var, the second digit is completly dark again. If i remove the decleration except i : byte; digit 2 starts lights again, but with the behaivor like in the film i posted. I don´t know if it's me, my AVR-controller or the AVRCO installation on my pc gone mad!!! Ha ha! :P I will try to write something that does the same as the Disp7port does to see if my hardware is faulty.
Kindest regards
Gepostet: 07.02.2015 - 21:20 Uhr  ·  #21
i don't know if this is relevant, but your stack and particularly your frame seems very small. The first digit looks OK, so I would certainly try doubling the frame and see if it makes a difference.
3xcs
Gepostet: 07.02.2015 - 21:55 Uhr  ·  #22
Thanks very much for the reply. I tried to set $0064 on both Stack and frame but the same result. Thanks anyway!
Kindest Regards
Gepostet: 07.02.2015 - 22:21 Uhr  ·  #23
What happens when you're connect PortC,3 to RCK ?
Please check the connections from right display.
Try this:
For i:=0 to 255 do
  Disp7Buff[0]:=i;
  Disp7Buff[1]:=i;
  DispRefresh;
  MDelay(1000);
  EndFor;
instead of your for...next loop.
both display should now count synchron binary up. Segment A=2^0 ..... segment G=2^6 ..... decimal point=2^7
You have already installed resistors between ICs and displays ?
  • Seite 3 von 3
MySQL Queries: 8 · Cache Hits: 13   121   134 · Page-Gen-Time: 0.014024s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
