Problem with Disp7sPort
3xcs
Gepostet: 04.02.2015 - 13:42 Uhr  ·  #1
Hello, i have a problem with Disp7sPort.
I´m running two 7seg digits nonmuxed with one TPIC6B595 Shift-register on each digit. The IC is equal , similar to 74HC595 but it can run big loads. I have connected the hardware like the example in DocuStdDriver.pdf. The problem is i only got one digit to work. always the second one in the chain, when i connect the Shift-registers the other way, swap the serial input and output between the shiftregisters the other digit works. So the hardware must be ok. Have i forgot something in the code? Or does the TPIC6B595 Shift-register not work with this Disp7sPort? Have anyone tried that IC?
My testprogram.
program test;
{ $WG} {global Warnings off}
Device = mega168, VCC=5;
{ $BOOTRST $01C00} {Reset Jump to $01C00}
// Override_Fuses;
NoteBook = A;
COMport = USB;
LockBits0 = [];
FuseBits0 = [];
FuseBits1 = [];
FuseBits2 = [];
Import SysTick, Disp7sPort;
From System Import ;
ProcClock = 16000000; {Hertz}
SysTick = 10; {msec}
StackSize = $0032, iData;
FrameSize = $0032, iData;
Disp7sPort = PortC, nonMux; {not multiplexed, Portbit}
DispMode = ShiftRight ;
DispDigits = 2, iData;
{ Type Declarations }
{ Const Declarations }
{ Var Declarations }
{ functions }
{ Main Program }
DISPclear;
mDelay(1000);
Write(DISPout,'12');
end test.
Kindest regards
Re: Problem with Disp7sPort
Gepostet: 04.02.2015 - 15:19 Uhr  ·  #2
Hello Thomas,
do you have a wiring diagram ?
Greetings
3xcs
Gepostet: 05.02.2015 - 11:35 Uhr  ·  #3
Hello Harry! Many thanks for the answer. Yes i have a very simple schematics on a piece of paper, i have scanned and attached it to this reply, hope it´s not to blurry. I have connected all the thing on a piece of veroboard so i don´t have a CAD schematics to share.
Kindest Regards Thomas
Gepostet: 05.02.2015 - 13:14 Uhr  ·  #4
Hello Thomas,
connect PortC,3 to RCK (not PortC,2). I think RCK is an Input for segment-driver.
Greetings
3xcs
Gepostet: 05.02.2015 - 14:02 Uhr  ·  #5
Hello! Thanks for the answer, and many thanks for the patience with me and taking of your time on my problem.
I tried to connect RCK to PortC,3 But then the both digits went dark.
I explored something now with my old PortC,2 - RCK-connection, when i define with use of only one digit with the same two digit hardware configuration i use.
DispDigits = 1, iData;
and run this in loop
for i:=0 to 20 do
Write(DISPout,BytetoStr(i));
mDelay(700);
endfor;
the result from the first forloop shows "0" on digit one and digit two is dark.
the loops that follows in the forloop shows this result.
digit one "1" digit two "0"
digit one "2" digit two "1"
digit one "3" digit two "2"
digit one "4" digit two "3"
digit one "5" digit two "4"
digit one "6" digit two "5"
and so on. So now is the both digits working but not the way it should. Strange.
Kindest Regards.
Gepostet: 05.02.2015 - 14:28 Uhr  ·  #6
With 1-Digit-configuration the displayed numbers are ok. The data are shifted from the first display in the second Display.But the driver knows nothing of the second display.
Do you have a oscilloscope ? With one display (DispDigits = 1, iData;) you should see 8 pulses on PortC,0 - with two displays (DispDigits = 2, iData;) 16 pulses. If not, is something wrong with the driver.
Sorry: Google-english :D
Greetings
Gepostet: 05.02.2015 - 14:47 Uhr  ·  #7
so with
the second digit will never be shown.
Gepostet: 05.02.2015 - 14:53 Uhr  ·  #8
Doch Rolf, wenn du ein weiteres Zeichen schickst, schiebt dieses das alte in das 2. Schieberegister weiter.
Es ist kein Clear angeschlossen.
MySQL Queries: 15 · Cache Hits: 14   134   148 · Page-Gen-Time: 0.022726s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
