Negative Bias for Graphics Displays
nwrightson
Herkunft: Newcastle
Homepage: nweha.homeserver.c…
Gepostet: 29.08.2003 - 14:06 Uhr  ·  #1
I've started using LCD Graphic displays (240*128) and all is going well except for the contrast. It changes a lot with temperature.
I can easily read the temperature using a DS75 I2C temp IC. Now I need to look up the required voltage and adjust the negative bias supply to the require amount.
So the question is, do you people have a preferance for a processor adjusted negative bias supply.
Thanks .
Neil.
Re: Negative Bias for Graphics Displays
Gepostet: 29.08.2003 - 20:50 Uhr  ·  #2
in the next version upload there will be an hard and software example
about controlling a positive and a negative voltage via the PWM of the
AVR.
nwrightson
Herkunft: Newcastle
Gepostet: 25.07.2011 - 09:00 Uhr  ·  #3
Hi Rolf,
Where is the above information?
Neil.
Gepostet: 25.07.2011 - 20:51 Uhr  ·  #4
Hello Neil,
sorry. 8 years ago. I can't find any info about this.
But a PWM to voltage converter is not very difficult. Simply integrate the PWM output with an RC filter and then pass it to an OP-Amp.
Negative voltages can be achieved with a C and two diodes inserted before this filter.
Higher voltages can be build with a diode ladder (simple charg pump) like used in old television devices.
nwrightson
Herkunft: Newcastle
Gepostet: 28.07.2011 - 09:30 Uhr  ·  #5
Hi Rolf,
Yes it has been a while. You used to have it on one of your schematics.
Oh well, I'll keep looking.
Neil.
Gepostet: 01.08.2011 - 12:28 Uhr  ·  #6
Hello Neil,
accidently I found my old test programm for a negative bias converter. But no hardware infos yet.
(* This program uses a PWMport, two diodes and a choke *)
(* to produce a negative voltage out of the 5V VCC     *)
program Inverter;
{ $BOOTRST $01C00}         {Reset Jump to $01C00}
{ $W+ Warnings}            {Warnings off}
Device = mega644, VCC=5;
//  Override_Fuses;
  NoteBook  = C;
  COMport   = USB;
  Supply    = 5, 200;
  LockBits0 = [];
  FuseBits0 = [SUT0];
  FuseBits1 = [SPIEN, JTAGEN, OCDEN];
  FuseBits2 = [BODLEVEL0, BODLEVEL1];
  ProgMode  = JTAG;
Import SysTick, SerPort, PWMport1A, PWMport1B, ADCPort;
From System Import ;
  SerPort        = 19200, Stop2;    {Baud, StopBits|Parity}
  RxBuffer       = 20, iData;
  TxBuffer       = 20, iData;
  ADCchans       = 3, iData, Int2;
  ADCpresc       = 128;
  PWMres1        = 8;              {bits}
  PWMpresc1      = 1;
  PWMmode1       = fast, negative;
    //  Load = 60mA     coil   47uH
    PWMport1B:= 90;     // ->  -2.4V an ADC @60mA
    //  Load = 10k      coil    220uH    >470uH<    1mH
    PWMport1A:= 6;      // ->  -3.1V      -2.5V     -2.5V
    mDelay(4000);
    PWMport1A:= 13;     // ->  -5.0V      -4.2V     -3.1V
    mDelay(4000);
    PWMport1A:= 25;     // ->  -8.5V      -6.1V     -3.8V
    mDelay(4000);
    PWMport1A:= 50;     // -> -17.0V     -12.4V
    mDelay(4000);
    PWMport1A:= 75;     // ->            -16.2V
    mDelay(4000);
end Inverter.
For heavy loads maybe it is necessary to use a small MOSfet driving transistor.
But for these very low currents drawn by LCDs this maybe not necessary.
nwrightson
Herkunft: Newcastle
Gepostet: 03.08.2011 - 03:43 Uhr  ·  #7
Hi Rolf,
How were the diodes and inductor connected?
Was a capacitor used for filtering/charge storage?
Neil.
P.S. I'm much better with digital and programming. I've never created a negative charge pump before.
Gepostet: 03.08.2011 - 09:51 Uhr  ·  #8
MySQL Queries: 14 · Cache Hits: 14   135   149 · Page-Gen-Time: 0.02234s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
