xMega A3,A2, and A1 with PortB
Problem with PortB as output
Jest
Gepostet: 20.06.2010 - 11:25 Uhr  ·  #1
having problem with xMega A3. On PortA I use ADC, but port B I need for I/O. And result is, that bits 0-3 acts as they should and other bits I can not change. For instance DDRB is $ff and PortB is $00, result on pins will read as %00001111. I have two different boards, different SW but same result.
Next step I started with STK600, 64A1 processor and LEDs connected to PortB. Running following simple code:
program xMega_test;
Device = xmega64A1, VCC=3.3;
{ $BOOTRST $08000}         {Reset Jump to $08000}
Import ;
  OSCtype        = int32MHz,                     //CPU=32MHz
                   PLLmul=4,
                   prescB=1,                     //PeripherX4=32MHz
                   prescC=1;                     //PeripherX2=32MHz}
  DDRB := $ff;
  EnableInts( $87);
    PortB := not PortB;
    mdelay( 500);
end xMega_test.
results with LED0 to LED3 blinking and others not.
Bug or I forgot to read proper page in manual? :'(
Best regards,
Andrej
P.S. Should read the manual - those ports are occupied by JTAG and should be disabled.
Txn Rolf for this, really important help.
MySQL Queries: 15 · Cache Hits: 13   36   49 · Page-Gen-Time: 0.022563s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
