Low drop diode
MOSFET as diode???
Jest
Low drop diode
Gepostet: 30.10.2010 - 09:47 Uhr  ·  #1
Hello,
I am losing my time on a field, that I do not know – MOSFET. Namely, in a design, I have two possible sources of voltage – it can be active any of them or both with max 150mA. Till now I was on 5V and to have two diodes BAT754 it was not so big drop in percentage.
Now I switched to 3,3V and every mV counts. On net I saw design with MOSFET as a low drop diode. Since I need two, I tried with IRF7754 with around 34mOhm ON resistance. Result? If I apply voltage on any of inputs, there is a short. :devil:
Do any have any idea where I made mistake or how to solve this other way? Tnx.
Best regards,
Andrej
Jest
Re: Low drop diode
Gepostet: 31.10.2010 - 09:39 Uhr  ·  #2
found the reason - not in wrong usage of MOSFET. There was 3,3V zener which was solded in wrong direction. :'(
Now, there is no short on power lines but MOSFETS are not working as diode - if I apply power to one input, I have it also on other. :(
Looks like, I will switch to more expensive solution an add two LTC4411 - increasing component count but it should work. 8-)
Andrej
MySQL Queries: 8 · Cache Hits: 13   51   64 · Page-Gen-Time: 0.010764s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
