Modbus Tester Error
'' not a valid integer value
torben33
Modbus Tester Error
Gepostet: 14.03.2011 - 08:50 Uhr  ·  #1
Hello,
after I have made some test with the modbus samples I have created my own
prog with the following ModBuff record (see below).
If I start the modbus tester and try to read once I get the message
'' is not a valid integer value.
This message occures also if I change the Modbuff record of the ASCII sample.
I have an older Compiler Version Compiler Rev. 4.83 maybe the problem is fixed with
a newer on (I have ordered) or do I make somthing wrong?
ModBuff[@ModDPR] : record // word byte
System_Mode : mb_RdWrB; // [00] 0 this is lo(ModDPR[0]) //Systemzustand
Operating_Mode : mb_RdWrB; // [00] 1 this is high(ModDPR[0]) //Testart
Comp_Mode : mb_RdWrB; // [01] 2 this is low(ModDPR[1]) //Kompressortype / Versorgung
Control_Mode : mb_RdWrB; // [01] 3 this is high(ModDPR[1]) //Zustand der Steuerung
Monitor_Mode : mb_RdWrB; // [02] 4 this is low(ModDPR[2]) //aktueller Überwachungsmodus
MgntVtlUse : mb_RdWrB; // [02] 5 this is high(ModDPR[2]) //Magnetventilverwendung freigeben
MonitorUse : mb_RdWrB; // [03] 6 this is low(ModDPR[3]) //Überwachung freigeben
VoltageActiv : mb_RdWrB; // [03] 7 this is high(ModDPR[3]) //Versorgungsspannung zugeschaltet?
OffTime : mb_RdWrW32; // [04] 8..11 Timervalue //Ausschaltzeit
OnTime : mb_RdWrW32; // [06] 12..15 Timervalue //Einschaltzeit
HiwiTime : mb_RdWrW32; // [08] 16..19 Timervalue //Hiwizeit
MonitorOffTime : mb_RdWrW32; // [10] 20..23 Timervalue //Überwachungsverzögerung
MgntVntlOnTime : mb_RdWrW32; // [12] 24..27 Timervalue //Einschaltverzögerung MagnetVentil
MgntVntlOffTime : mb_RdWrW32; // [14] 28..31 Timervalue //Abschaltverzögerung des Magentventils
SysStat : mb_RdWrW; // [16] 32..33 //Systemzustand alt
TempL : mb_RdWrW; // [17] 34..35 //Messwerte
GDL : mb_RdWrW; // [18] 36..37
SDL : mb_RdWrW; // [19] 38..39
IL : mb_RdWrW; // [20] 40..41
TempR : mb_RdWrW; // [21] 42..43
GDR : mb_RdWrW; // [22] 44..45
SDR : mb_RdWrW; // [23] 46..47
IR : mb_RdWrW; // [24] 48..49 //Messwerte
AktPrescale : mb_RdWrW; // [25] 50..51 //Vorteilerwert
ActRPM : mb_RdWrW; // [26] 52..53 //aktueller Drehzahlwert
MaxRPM : mb_RdWrW; // [27] 54..55 //minimaler Drehzahlwert
MinRPM : mb_RdWrW; // [28] 56..57 //maximaler Drehzahlwert
StepTime : mb_RdWrW32; // [29] 58..61 Timervalue
Step : mb_RdWrB; // [30] 62 this is low(ModDPR[30]) // Step(index) aktuelle Drehzahl
StepMinindex : mb_RdWrB; // [30] 63 this is high(ModDPR[30]) //
StepMaxIndex : mb_RdWrB; // [31] 64 this is low(ModDPR[31]) //
StepIndex : mb_RdWrB; // [31] 65 this is high(ModDPR[31]) //
StepInc : mb_RdWrB; // [32] 66 this is low(ModDPR[32]) // Step-Richtung (rauf / runter)
I2CLEDs : mb_RdWrB; // [32] 67 this is high(ModDPR[32]) // Ledzustand
Re: Modbus Tester Error
Gepostet: 14.03.2011 - 13:30 Uhr  ·  #2
torben33
Gepostet: 05.04.2011 - 14:26 Uhr  ·  #3
ich habe das oben beschriebene Problem mit dem ModbusTester.
Fehlermeldung: '' is not a valid integer value
Dieses existiert weiter auch mit dem neuesten Software Download 4.99.33.
Gibt es eine Lösung bzw. die neuere Version von der Avra spricht an anderer Stelle?
Gepostet: 05.04.2011 - 17:54 Uhr  ·  #4
Hallo Torben,
nein, es gibt keine neuere Software. Da ich z.Zt. mit wesentlich wichtigeren Teilen des AVRco beschäftigt bin, kann ich auch keinen Termin dafür nennen. Sorry.
Gepostet: 06.04.2011 - 08:36 Uhr  ·  #5
Sorry for bringing confusion. I thought it was fixed.
@Torben: Take a look at this thread (http://forum.e-lab.de/topic.php?t=2406) and see if manual modification of PMBL file described there could help you as a temporary workaround.
torben33
Gepostet: 08.04.2011 - 15:26 Uhr  ·  #6
Hello,
I found a work around for this problem of the modbustester error message '' is not a valid integer value .
If you put in the lights and various_flags from the modbus Ascii Demo at the End of your Modbuff record the program works:
lights : tLightSet; // [38] 74..75
various_flags : tFlagsSet; // [39] 76..77
I think the programm has a problem not to find any kind of coils and discret inputs.
Thank you for your help.
Gepostet: 11.04.2011 - 14:34 Uhr  ·  #7
You are welcome. ;-)
I am glad that you have found a work around.
MySQL Queries: 8 · Cache Hits: 14   112   126 · Page-Gen-Time: 0.015475s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
