TickTimerTime
Mr Crusty
TickTimerTime
Gepostet: 12.12.2011 - 20:17 Uhr  ·  #1
Clarification needed with the Function TickTimerTime.
In the Standard Driver pdf. it says that the timer is stopped and new values are written to the prescaler and compare registers.
It appears that the timer restarts after exiting the procedure, is this correct?
Crusty.
Re: TickTimerTime
Gepostet: 12.12.2011 - 20:51 Uhr  ·  #2
Hello Crusty,
after calling TickTimerTime the application should call TickTimerStart because the Timer Interrupt maybe disabled at this time. Of course, all internal Vars became reset.
Re: TickTimerTime
Gepostet: 12.12.2011 - 20:59 Uhr  ·  #3
Hi Crusty,
have a look to the demo!
// 10usec repeated interrupt
// toggles the enabled output pin with 10usec high / 10usec low
TickTimerTime(10); // writing a new value automatically stops the timer
TickTimerStart; // timer restart
Mr Crusty
Re: TickTimerTime
Gepostet: 12.12.2011 - 21:28 Uhr  ·  #4
Hi Rolf, Gunter,
Thanks for fast reply.
Can you advise why I have to put a TickTimerStop in the interrupt routine.
In the simulator, interrupt continues after a new time is set in interrupt with TickTimerTime.
Am I doing something stupid?
Crusty
program TTTest;
{ $WG} {global Warnings off}
Device = mega328, VCC=5;
{ $BOOTRST $03800} {Reset Jump to $03800}
// Override_Fuses;
NoteBook = A;
COMport = USB;
LockBits0 = [];
FuseBits0 = [];
FuseBits1 = [];
FuseBits2 = [];
Import SysTick, TickTimer;
From System Import LongWord;
ProcClock = 16000000; {Hertz}
SysTick = 10; {msec}
StackSize = $0064, iData;
FrameSize = $0064, iData;
TickTimer = Timer1;
{ Type Declarations }
{ Const Declarations }
{ Var Declarations }
{ functions }
Interrupt TIMER1COMPA; // TickTimer
TickTimerTime(30);
//TickTimerStop;
{ Main Program }
TickTimerTime(20);
TickTimerstart;
end TTTest.
Re: TickTimerTime
Gepostet: 13.12.2011 - 00:11 Uhr  ·  #5
Hello Crusty,
you manipulate the ticktimer driver in the ticktimer interrupt??!!
Very strange...
Re: TickTimerTime
Gepostet: 13.12.2011 - 10:52 Uhr  ·  #6
Hi Mr Crusty.
Here is my guess.
TickTimers generate interrupts and are stopped/started by a combination of interrupt flags and enable/disable interrupts. You need to be aware that entering an interrupt routine has an implied disabling of interrupts and exiting it (which generates a RETI rather than a RET) re-enables interrupts. I don't know the exact mechanism but I am guessing that the enabling of interrupts on exiting the procedure in this case restarts the timer countdown.
I would recommend that you use flags or pipes and manipulate the timer outside the interrupt.
Mr Crusty
Re: TickTimerTime
Gepostet: 13.12.2011 - 21:02 Uhr  ·  #7
Hi Merlin, Rolf and Gunter,
Thanks for all the feedback.
I agree that it's a bit odd to put the manipulation of TickTimer in the interrupt.
Especially as this takes some time to complete. No longer being used.
However I did some more tests and I still find that in the simulator TickTimer, if already started, does no stop and does not need a new implicit TickTimerStart after the use of TickTimerTime.
Not a problem as I am using a TickTimerStop where required.
I include the 3 bits of code that I have tried in the testing.
Again many thanks for the support of the team and other users
Crusty. :-)
program TTT_2;
Device = mega328p, VCC=5;
// Override_Fuses;
NoteBook = A;
COMport = USB;
LockBits0 = [];
FuseBits0 = [];
FuseBits1 = [];
FuseBits2 = [];
TickTimer = Timer1;
Dummy, Flag : Boolean;
{ functions }
Flag := True; //set breakpoint in simulator here
{ Main Program }
Dummy := False;
TickTimerTime(40); //TickTimer does not interrupt as never started
While Dummy = False Do
NOP;
EndWhile;
end TTT_2.
Dummy := False;
TickTimerTime(40);
TickTimerStart; //TickTimer Interrupts always as no stop
NOP;
EndWhile;
end TTT_2.
Dummy := False;
Flag := False;
TickTimerTime(40);
TickTimerStart;
If Flag = True then TickTimerTime(60); //TickTimer interrupts even after new value set.
Flag := False;
Endif;
EndWhile;
end TTT_2.
Re: TickTimerTime
Gepostet: 14.12.2011 - 21:28 Uhr  ·  #8
Hello Crusty,
I checked the driver and found out that the Timer Interrupt is not disabled with "TickTimerTime".
So calling this function the interrupt still fires without a "TickTimerStart". If this behaviour is not desired I can change it.
MySQL Queries: 8 · Cache Hits: 14   134   148 · Page-Gen-Time: 0.015686s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
