Avrco command line usage
Jeroen.Vandezande
Gepostet: 10.03.2012 - 15:20 Uhr  ·  #1
After I lost some .pas files this week because I forgot to check them into subversion I am planning to setup a continuous integration server.
Not only for Avrc but for all my code.
Now for Avrco I noticed that I can compile a .ppro file using the AvrCo.exe on the command line.
In the PED editor I can do also syntax check and then I do not need the programmer dongle to be attached. Is there any way to tell Avrco.exe that it only needs to do a syntax check en thus not needing a dongle (this will run on a server)
I noticed that I can find the compiler errors in the .err file and that can be passed to the CI server.
Best Regards,
Jeroen
Re: Avrco command line usage
Gepostet: 10.03.2012 - 18:04 Uhr  ·  #2
Hello Jeroen,
for a syntax check of a compile run you must append a -S to the commandline.
Jeroen.Vandezande
Gepostet: 11.03.2012 - 11:07 Uhr  ·  #3
thank you for the quick reply!
Jeroen.Vandezande
Gepostet: 20.03.2012 - 17:07 Uhr  ·  #4
I was able to setup my CI server (I am using Jenkins http://jenkins-ci.org/ ) but I had to do some tricks to get it working...
AvrCo.exe shows a small GUI window while compiling... Is there a way to disable that?
Because Jenkins is running as a windows Service all child processes (including AVrco) can not produce standard windows GUI screens. This causes AvrCo to crash and run at 100% cpu.
I found a complex solution for this, but I wonder if there is no command switch I can use to disable this...
Best Regards,
Jeroen
Gepostet: 21.03.2012 - 14:26 Uhr  ·  #5
Hello Jeroen,
this little form is absolutely necessary, visible or not. It serves as an anchor for the compiler.
MySQL Queries: 15 · Cache Hits: 14   93   107 · Page-Gen-Time: 0.02363s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
