Atmega32u4 USB support
nwrightson
Herkunft: Newcastle
Homepage: nweha.homeserver.c…
Gepostet: 01.12.2012 - 07:39 Uhr  ·  #1
Hi All,
I'm looking to buy a LeoStick and I'm wondering what USB support the Atmega32u4 has?
Are there any AVRCo drivers for the USB interfaces in the Mega chips yet?
I would like to communicate with a configuration application on the PC.
Neil.
Re: Atmega32u4 USB support
Gepostet: 02.12.2012 - 13:21 Uhr  ·  #2
Hello Neil,
I accidentially deleted your last posting :'( . Sorry!
But why do you use this outdated Mega? The XMega32A4U is cheaper, faster and has an improved and much better internal USB hardware.
btw.
Atmel's strategy is to replace most of the current Megas by XMegas, which are cheaper and much more powerful. So new designs or redesigns should always use XMegas, if possible.
nwrightson
Herkunft: Newcastle
Gepostet: 02.12.2012 - 20:53 Uhr  ·  #3
Because it is already made.
So can I -
1. program it from avrco using the USB interface and atmels built in loader?
2. Does avrco support the USB functionality on this device?
3. The mega 128u sample program won't compile, error with missing endpoints.
Neil.
Gepostet: 02.12.2012 - 23:15 Uhr  ·  #4
Hi Neil,
my old Testprog wolks fine with Atmega32u.
1. no
2. yes. see my sample
3. little define error in AVRco !
program Echo;
{ $NOSHADOW}
{ $WG-}                      {global Warnings on}
//Device = 90USB128, VCC=4.5;
//Device  = 90USB162,VCC=4.5;
//Device  = mega16U2;
Device  = mega32U4,  VCC=3.3;
//Device = mega32U6;
All CPU define were used only for my  development.
Atmel USB Devices Defines
{$IFDEF _USB16U4_32U4} -> Mega16U4, Mega32U4
{$IFDEF _USB32_64}     -> Mega32U6, 90USB64/646/647
{$IFDEF _USB128}       -> 90USB128/1286/1287
{$IFDEF _USB82_162}    -> 90USB82, 90USB162
{$IFDEF _USB8U2_32U2}  -> Mega8U2, Mega16U2, Mega32U2
  Override_Fuses;
  NoteBook       = B;
  COMport        = USB;
  Supply         = 5.0, 100;
  LockBits0      = [];
  FuseBits0      = [];
{$IFDEF _USB128}
  FuseBits1      = [SPIEN, JTAGEN, OCDEN];
{$ELSE}
  FuseBits1      = [SPIEN];
{$ENDIF}
  FuseBits2      = [];
{$IFDEF _USB16U4_32U4 or _USB128}
  ProgMode       = JTAG;
{$ELSE}  // Mega8U2, Mega16U2, Mega32U2  ,162
  ProgMode       = SPI;
{$ENDIF}
Import SysTick, USBport,  BeepPort, WatchDog;
{$ELSE}
Import SysTick, USBport,  BeepPort, SerPort1;
{$ENDIF}
From System Import;
  StackSize      = $090, iData;
  FrameSize      = $090, iData;
{$IFNDEF _USB16U4_32U4}
  SerPort1        = 19200;
{$ENDIF}
{$IFDEF _USB128}
  BeepPort       = PortE, 5;
{$ELSIFDEF _USB16U4_32U4}
  BeepPort       = PortE, 2;  // MIRFscanner
{$ELSIFDEF _USB8U2_32U2}
  BeepPort       = PortD, 7;
{$ELSE}
  BeepPort       = PortD, 7;   // dummy
{$ENDIF}
//{$IFDEF _USB128}
  USBvid         = $9124;                // Vendor-ID
  USBpid         = 30;                  // Product-ID
  USBprodRel     = 201;                // Product-Release
  USBmanufact    = 'E-LAB Computers';
  USBprodName    = 'EvaBoard USB128';
  USBcurrent     = 200;                 // max current consumption
  USBsernum      = 2143;                // Product serial number
  USBendpoints   = 1;                   //  !!!!  help to compile until Rolf resolved  this :)
{$ELSE}
  USBvid         = 9876;
  USBpid         = 1234;
  USBprodRel     = 3210;
  USBprodName    = 'EvaBoard USBxxx';
  USBcurrent     = 200;
  USBsernum      = 7264;
{$ENDIF}
Uses uAVR_USB;
  USBrxBuf       : array[0..63] of byte;
  USBtxBuf       : array[0..63] of byte;
  Str63[@USBTxBuf[1]] : String[63];
  USBrxBuf8      : tEp3_4Buf,Align2;
  USBtxBuf8      : tEp3_4Buf,Align2;
  Str8[@USBTxBuf8[1]] : String[7];
  cnt            : Word;
Procedure myUserProc( x : byte;  v : word);
 // WatchDogStart;
  USBsetUserProc(@myUserProc);
  mDelay(500);
 // USBsetTimeOut(100);
  USBinit;
{$ifdef XMega}
  EnableInts($87);
{$else}
{$endif}
  BeepOutHL;
  WriteLn(SerOut1, 'E-LAB USB Test');
 {$ENDIF}
  While not USBconnected do
    BeepClick;
    SerOut1('x');
    {$ENDIF}
    mDelay(300);
  endwhile;
  WriteLn(SerOut1);
  WriteLn(SerOut1, 'connected');
 {$ENDIF}
 Str63:='E-Lab Computers';
 Str8:='E-Lab C';
    if USBgetRxState8 > 0 then
      //cnt:=USBgetRxBuf8(USBrxBuf8);
    if USBgetTxState8 > 0 then
      USBsetTxBuf8(USBtxBuf8);
    if USBgetRxState > 0 then
      cnt:= USBgetRxBuf(@USBrxBuf, SizeOf(USBrxBuf));
      // Writeln(Serout,IntToStr(cnt));
    if USBgetTxState > 0 then
      //WriteLn(SerOut, 'DownLen: '+IntToStr(USBgetTxState));
      cnt:= USBsetTxBuf(@USBtxBuf, SizeOf(USBtxBuf));
    if SerStat then
      case SerInp of
        'D', 'd' : USBclose;     // detach, disconnect
        'C', 'c' : USBinit;      // re-init
        'S', 's' : if USBconnected then
                     SerOut1('c');
                     SerOut1('x');
                   endif;      // status, connected
        //BeepOut(1000, 10);
        SerOut1('?');
      endcase;
   {$ENDIF}
end Echo.
Gepostet: 03.12.2012 - 20:51 Uhr  ·  #5
Hello Neil,
USBendPoints are fixed in the MeagaUSB driver. So the define of EndPoints isnot necessary and is ignored.
Don't forget to define the Watchdog. It is necessary to send a hardware RESET via Endpoint0.
nwrightson
Herkunft: Newcastle
Gepostet: 03.12.2012 - 21:36 Uhr  ·  #6
Rolf,
Then why doesn't your Demo EVA128USB compile?
It gives an Error "Define of USBendpoints 1..2 Expected"
Neil.
Gepostet: 04.12.2012 - 00:04 Uhr  ·  #7
Hello Neil,
it is a bug but removed now. In the next update this define will be ignored.
MySQL Queries: 8 · Cache Hits: 14   128   142 · Page-Gen-Time: 0.015417s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
