Which timer/counters are used by the compiler in Xmega chips?
xmega, systimer
bgoolsby
Gepostet: 21.07.2013 - 12:56 Uhr  ·  #1
Which of the Xmega hardware timer/counters are used by the compiler when you import Systimer? Conversely, which are free for us to use in programs?
Re: Which timer/counters are used by the compiler in Xmega chips?
Gepostet: 21.07.2013 - 13:09 Uhr  ·  #2
see DocuCompiler.pdf, chapters 4.18.7.1 and 4.18.7.2 !
A "SysTimer" is based on the SysTick. So no additional hardware timer is involved.
But think of the resolution and precision of the SysTick. It is not very high and
so not usable for real timing functions.
If you need a more precise one, you can use the "TickTimer" which then needs a
separate 16bit timer.
bgoolsby
Gepostet: 21.07.2013 - 14:54 Uhr  ·  #3
If Systick is imported, it uses one of the timers, correct? On the Mega chips I think this is Timer0. On the Xmegas, does it use TCC0?
Also, I note that the new Xmega E5 doesn't have TCC0; it has TCC4, TCC5 and TCD5.
Gepostet: 21.07.2013 - 17:17 Uhr  ·  #4
With XMegas the SysTick uses the 16bit RTC Timer "RTC".
If this timer is not present any other of the standard timers
can be used. Please read the compiler manual as Gunter wrote.
Also the E5 series have the RTC timer/counter usable for SysTick.
bgoolsby
Gepostet: 21.07.2013 - 17:28 Uhr  ·  #5
OK, I read the compiler pages and understand now. Thanks.
bgoolsby
Gepostet: 06.02.2014 - 16:53 Uhr  ·  #6
What if the Xmega does have an RTC, like the Xmega256A3U? Can I still use a standard timer if I want to by using the code in the compiler manual, "4.18.7.2 XMega SYSTICK without RTC Timer"?
Gepostet: 06.02.2014 - 18:47 Uhr  ·  #7
yes, you can do it. But what do you expect from this?
bgoolsby
Gepostet: 06.02.2014 - 19:18 Uhr  ·  #8
The RTC timer is 1.024ms, not exactly 1ms. I was thinking of getting more exact timing with one of the conventional TC's. How much adjustment can the "adj" option make to the RTC? Can that make it exactly 1ms?
MySQL Queries: 14 · Cache Hits: 14   132   146 · Page-Gen-Time: 0.020924s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
