Pointer to eeprom
PeterN
Pointer to eeprom
Gepostet: 25.11.2013 - 16:47 Uhr  ·  #1
Hello all,
I'm new on the forum but already several years busy with Avrco.
I've a small question about a project with the Mega:
I need to copy data from an external eeprom to the internal mega eeprom.
If I implement:
TwiInpP(ExtEepAdres,@Eeprom[$0100],$0040)
it won't work. Problem I gess is that pointer to internal Eeprom isn't allowed here?
Of course I can read every single byte in a buffer variable and write it, but is there no solution (like pointers) to copy every eeprom page in block? Because I'm running out of Ram I don't want to use an extra buffer in ram to do so.
Thanks for helping ;)
Re: Pointer to eeprom
Gepostet: 25.11.2013 - 19:23 Uhr  ·  #2
Hello Peter,
it is physically impossible to move a block into the internal EEprom.
Only a byte wise writing can be done, because before or after any
byte written, the EEprom busy must be checked. Also the AVRco
internal EEprom block writes break a block into bytes and makes
single byte writes from it.
So you must use a byte-read byte-write in a loop if you must avoid
using an intermediate buffer. And also with a buffer, at least a byte
wise write is done by the system.
PeterN
Gepostet: 26.11.2013 - 00:37 Uhr  ·  #3
Thank you for the explanation. I will use a loop, it's not time critical so it's possible to do byte read byte write.
Peter(y)
Gepostet: 26.11.2013 - 14:21 Uhr  ·  #4
Hello Peter,
don't care about the code time. Each EEprom write byte takes a few msec
because the internal busy must be timed out.
MySQL Queries: 15 · Cache Hits: 14   79   93 · Page-Gen-Time: 0.023883s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
