RC5 problem
Peter KWS
RC5 problem
Gepostet: 18.12.2013 - 12:17 Uhr  ·  #1
Hi all. I have a question about RC5.
When I tested RC5 data transmission with Mega8/Tsop1736/Xtall 16Mhz
rutine
if RecvRC5(RXadresa, RXdata) then
Toggle(LED);
Endif;
work fine.
When I tested RC5 data transmission with Mega8/Tsop1738/Xtall 16Mhz
rutine
Toggle(LED);
Endif;
work only when is ProcClock = 8000000Mhz. But Xtall is 16Mhz.
Any idea?
Thanks Peter.
Re: RC5 problem
Gepostet: 18.12.2013 - 14:13 Uhr  ·  #2
Hello Peter,
the first example runs with 8MHz? Or the second one? Its not clear for me.
Re: RC5 problem
Gepostet: 18.12.2013 - 16:20 Uhr  ·  #3
Hello Peter,
did you check, that the fuses of both megas are really set the same?
What happens with a test loop
toggle (led);
mdelay (500);
endloop
Do you see the same blink frequency?
Peter KWS
Re: RC5 problem
Gepostet: 18.12.2013 - 19:12 Uhr  ·  #4
First example runs normaly with TSOP 1736 (36khz) / 16Mhz xtall and Procclock in program set normaly 16000000.
When i disconnect TSOP1736 and connect TSOP 1738 (38Khz), TX freq. change from 36khz to 38khz, program not detect RC5 Rcv. But when i change in program procclock to 8000000(xtall still 16Mhz) work fine, but example
Loop
Toggle(Led);
Mdelay(500);
Endloop;
Speed of toggle led is not 500ms.
Maybe is problem in programmer, i use ISP MK2 and AVRSTUDIO to write hex to MCU.
Peter KWS
Re: RC5 problem
Gepostet: 18.12.2013 - 19:28 Uhr  ·  #5
One mega8, one IR diode, one program and two tsop sensors 36 and 38
Re: RC5 problem
Gepostet: 18.12.2013 - 23:05 Uhr  ·  #6
Hello Peter,
please take an oscilloscope or similar and look onto the driver signal to the TSOP.
Here you should see the real clock frequency, 36 or 38kHz
Peter KWS
Re: RC5 problem
Gepostet: 19.12.2013 - 17:38 Uhr  ·  #7
Ok i try it, thanks and nice christmas for all :)
MySQL Queries: 15 · Cache Hits: 14   126   140 · Page-Gen-Time: 0.025099s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
