Using RTC32 as RTCsource on Xmega256A3BU
RTC32, A3BU
bgoolsby
Gepostet: 11.03.2014 - 21:58 Uhr  ·  #1
I am using an Xmega256A3BU in an application. I have an external 32.768KHz crystal and battery backup installed. This chip has the battery backup functions and a 32-bit RTC module. I have the RTC32 working; i.e. I can read the RTC32 CNT register and verify that it updates once/second and that it continues to count when the main power is off.
I want to use RTC32 as the RTCsource for AVRco's RTclock driver. Is this possible? Doing this would enable me to use the date and time functions provided by RTclock and have the clock keep running during power down.
Re: Using RTC32 as RTCsource on Xmega256A3BU
Gepostet: 15.03.2014 - 13:56 Uhr  ·  #2
sorry, with XMegas only the SysTick can be used as a source for the RTC at this time.
But what do you expect from the hardware RTC timer? This part is counting up every
second. But this doesn't help if the CPU is sleeping. So this timer must do an interrupt
every second/tick and then update the AVRco RTC and then going to sleep again.
If this is what you expect we can extend our RTC so that in such an interrupt the
RTC driver can be called and the become updated.
But you must setup the hardware RTC timer by yourself and program this interrupt
and sleep sequence by your own.
MySQL Queries: 15 · Cache Hits: 14   50   64 · Page-Gen-Time: 0.021458s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
