Compiler switches
work even if they do not start on 1st column
Compiler switches
Gepostet: 16.06.2014 - 10:25 Uhr  ·  #1
Compiler manual says:
The switches must start in the first column of a line.
I have worked with this limitation for many years, and my complex code looked ugly where I had to comply to this rule and avoid code indentation. However, in code example below {$X-} switch works even when intended in code:
{ $D-} // do not step following code in debuger
procedure mDelaySim(const msec: word);
  {$X-} // do not execute following code in simulator
  mDelay(msec);
  {$X+}
{ $D+}
Does this mean that compiler finally doesn't care if we intend compiler switches to beautify our code? If so then manual should be updated.
:3some:
btw. I am aware of {$DEBDELAY} and "Short mDelay" menu switch in simulator, but there is code with many delays where my mDelaySim() is essential for simulation.
Re: Compiler switches
Gepostet: 16.06.2014 - 11:11 Uhr  ·  #2
Hello Avra,
this is correct. Thise note should be removed from the manual.
Gepostet: 16.06.2014 - 13:43 Uhr  ·  #3
:blob4: :blob5: Yipeeee! :blob5: :blob4:
MySQL Queries: 15 · Cache Hits: 14   58   72 · Page-Gen-Time: 0.019881s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
