using locked in a type
Gepostet: 21.06.2014 - 22:54 Uhr  ·  #1
It would be very nice to be able to define a type which will be used to instance locked variable:
  TRawNum = integer, locked;        //   <<<<<   NOT POSSIBLE :-(
  TAiRuntime = record
    Eng: TSomeNotImportantType;
    Raw: TRawNum;                   //   <<<<<   NOT POSSIBLE :-(
  LockedVar: integer, locked;       //   <<<<<   POSSIBLE :-)
  AI: array[1..64] of TAiRuntime;   //   <<<<<   NOT POSSIBLE :-(
I have complex structures existing in runtime records accessed by different processes, and there are for example commands similar to this one:
  Runtime.AI[4].Raw.Value := SomeValue;
It would really be nice to be able to lock such variables nested in typed records. Without such a feature I have to give up either locking or typed records, or write ugly disable/enable interrupt workaround wrapper for each variable access.
Re: using locked in a type
Gepostet: 23.06.2014 - 15:09 Uhr  ·  #2
Hi Avra.
I know you only want to lock an element within a record within an array, but surely it does no harm to lock the entire array?
  AI: array[1..64] of TAiRuntime, locked;
is permitted.
Gepostet: 23.06.2014 - 16:04 Uhr  ·  #3
Hello Avra,
sorry, locking a part of an array or record is impossible here.
But you can simply do it like Merlin suggested.
Or implement your own locking like the compiler does it.
NoInts;
  any access...
restoreInts;
Gepostet: 23.06.2014 - 20:19 Uhr  ·  #4
My complex structure in RAM is 1614 bytes and in EEPROM it is 1442 bytes, so locking the whole structures is not wanted when there are only few hundred bytes that are critical for locking. I will live with a manual locking wrapper in code around each variable access.
Merlin and Rolf, thank you both for looking at my problem.
MySQL Queries: 8 · Cache Hits: 14   73   87 · Page-Gen-Time: 0.013702s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
