alias problem
alias problem
Gepostet: 22.06.2014 - 01:41 Uhr  ·  #1
I have a shared unit with serial communication protocol process, and in it's uses section there is a project dependent unit which defines aliases like this:
alias
  // Communication protocol will be on serial port 2
  SerInpComm   = SerInp2;   // serial port alias
  RxBufferComm = RxBuffer2; // serial buffer alias
In theory that should let me use communication protocol in many projects running on different ports defined in that project dependent unit.
First I had a problem which could be simplified to this code snippet:
    MyStr := SerInp2 + SerInp2;                   // this works
    MyStr := SerInpComm + SerInpComm;             // doesn't compile
    MyStr := char(SerInpComm) + char(SerInpComm); // workaround
As you can see I have solved this problem with a workaround.
But then this showed up which I don't know how to solve:
  if WaitPipe(RxBufferComm, COMM_TIMEOUT_TICKS) then // compilation error
Is there some workaround for using alias with WaitPipe()?
Re: alias problem
Gepostet: 22.06.2014 - 19:37 Uhr  ·  #2
Hello Avra,
Alias is only active for one, the next, statement.
Re: alias problem
Gepostet: 22.06.2014 - 21:31 Uhr  ·  #3
Sorry, I think that I just don't get it since your answer confused me even more and my understanding of XMega_Alias demo and compiler documentation. Especially since in demonstration code below these two lines using aliases compile:
  c := SerInpComm;
  Write(SerOutComm, c);
and this one does not compile:
  WaitPipe(RxBufferComm)
Changing alias order or code order didn't make any difference. Trying to use alias RxBufferComm breaks compilation. :crybaby:
Could you please tell me what I need to change to be able to use RxBufferComm alias since that is not obvious to me and I still don't get it? :wall:
program Test;
device = mega64, VCC=3.3;
import SysTick, SerPort, SerPort2;
from System import Processes;
define
  Scheduler      = iData;
  SerPort        = 9600, Stop1;    {Baud, StopBits|Parity}
  RxBuffer       = 8, iData;
  TxBuffer       = 8, iData;
  SerPort2       = 9600, Stop1;    {Baud, StopBits|Parity}
  RxBuffer2      = 8, iData;
  TxBuffer2      = 8, iData;
implementation
alias
  RxBufferComm = RxBuffer; // serial port input buffer alias
  SerInpComm   = SerInp;   // serial port input alias
  SerOutComm   = SerOut;   // serial port output alias
process HcpComm($40, $100: iData);
  c: char;
  //WaitPipe(RxBufferComm); // COMPILER ERROR: var expected
  WaitPipe(RxBuffer);       // workaround without alias works
  c := SerInpComm;
  Write(SerOutComm, c);     // echo input
  Start_Processes;
  WriteLn(SeroutComm, 'I will echo your typing...');
    nop;
end Test.
Re: alias problem
Gepostet: 22.06.2014 - 22:00 Uhr  ·  #4
Hello Avra,
sorry, my mistake. Of course ALIAS is valid until the next var or const label appears.
Re: alias problem
Gepostet: 22.06.2014 - 22:32 Uhr  ·  #5
So why in above code this line can not compile when uncommented:
There is no const or var between alias and this line. I have moved procedural var into global var so there is not a single var at all between alias and this line and I still can not compile.
What do I need to change to be able to compile above code when using RxBufferComm alias?
Re: alias problem
Gepostet: 23.06.2014 - 13:36 Uhr  ·  #6
Hello Avra,
WaitPipe is a very special construction and was not intended to be
used with ALIAS. But now it is supported.
Re: alias problem
Gepostet: 23.06.2014 - 20:05 Uhr  ·  #7
I have tested and... IT COMPILES, IT COMPILES IT COMPILES !!! :D
=D> :-({|= =D> :occasion7: 👋
Now I can share communication unit between different projects without tons of ugly IFDEFs covering all possible AVR serial ports combination in code.
🆒 :juggle:
THANK YOU ROLF!
:cheers: :occasion5: 👍
Re: alias problem
Gepostet: 23.06.2014 - 20:40 Uhr  ·  #8
Hello Avra,
some things are easy to implement, like this one.
Others are not, like passing bits to a function.
MySQL Queries: 8 · Cache Hits: 14   126   140 · Page-Gen-Time: 0.016801s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
