EEpromPointer
fve
EEpromPointer
Gepostet: 07.07.2014 - 10:05 Uhr  ·  #1
Hi all,
I got some code from a colleague, when compiling, i notice i get errors when pointing to eeprom.
for example:
i have a boolean stored in eeprom:
Set_value[$08C8] : boolean;
UParaPntr : pointer;
UParaPntr:= (@Set_value);
The compiler givers me the error:
"Error: Pointer to EEprom not possible"
When my colleague compiles, everyting works fine.
I know i need to call a special function to get/set the value in eeprom using a pointer.
but it goes wrong when i make the pointer refere to the eeprom address..
Do i have to set some special bit to enable pointers to EEprom?
The only difference between my version and the one of my colleague is that he has a newer version of the compiler.
(i am working with revision 5.04.32, but when i read the changes since my version, i notice nothing about pointer to eeprom)
Regards,
Flor
fve
Re: EEpromPointer
Gepostet: 08.07.2014 - 09:32 Uhr  ·  #2
Is there anyone who has an idea why my compiler gives errors when using pointers to eeprom?
Was this functionality added in a later version of the compiler? After 5.04.32? (i supose not, since i find references in the documentation of my compiler..)
i'm using an atmega 2560..
Regards,
Flor
Herkunft: Sauerland NRW
Re: EEpromPointer
Gepostet: 08.07.2014 - 10:13 Uhr  ·  #3
Hi Flor,
the information you give is quite frugal. Anyway, I have added
{$EEPROM}
StructConst
Set_value[$08C8] : boolean = TRUE;
to my program header, I have added
to my variable definition and I added into the source just before the main loop
Everything compiles fine. (ACRco 5.04.72) I have tried an older version of the compiler (5.04.24), and that compiled too.
For further investigation it would be helpful, if you post a full, tiny test program, that shows the error.
Michael
Re: EEpromPointer
Gepostet: 08.07.2014 - 13:23 Uhr  ·  #4
Flor, just a quick question. You are not trying to store the pointer in EEPROM are you? That is what the error message suggests.
fve
Re: EEpromPointer
Gepostet: 08.07.2014 - 16:21 Uhr  ·  #5
Hi Merlin,
No, i declaired my variable in eeprom,
The pointer is declaired in another unit, as a variable in ram...
the error "Pointer to EEprom not possible", referes to all the lines where i let the pointer point to the variables stored in eeprom..
unit E_Dec;
interface
{$EEPROM}
procedure xxx;
end
But when i open the project in the old IDE, using version 5.04.32, i stell get the errors.
The good news is that i updated the software and now everything compiles as it should (5.04.77).
So i'll be working in version 5.04.77 from now on.
Thanks for looking into the problem anyway,
Regards,
Flor
MySQL Queries: 8 · Cache Hits: 14   92   106 · Page-Gen-Time: 0.014193s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
