Debug_Break dependable on compiler switch?
Gepostet: 03.12.2014 - 19:48 Uhr  ·  #1
@Rolf,
if it's not too much work, is it possible to implement compiler switch something like this:
{$IGNORE_DEBUG_BREAK}
so when it's defined, DEBUG_BREAK (or my custom alias based shorter "Dbg" version) commands in code will simply be ignored by debugger? That way we could leave them in code if we wish without tons of ugly ifdefs.
With additional
{$ENABLE_DEBUG_BREAK}
we could use this feature on just part of the source (like few new procedures in our latest unit)...
Re: Debug_Break dependable on compiler switch?
Gepostet: 03.12.2014 - 20:53 Uhr  ·  #2
Hello Avra,
sorry, absolutely impossible because the "Debug_Break" instruction is a real
hardware executable CPU instruction.
The XMega ignores it when it is not in Debug mode, PDI inactive.
In this case this instruction is handled by the CPU as a NOP.
So there is no problem if you leave these instructions in your code.
Simply a few unnecessary NOPs are added.
But in Debug mode these instructions are always active, sorry.
Gepostet: 04.12.2014 - 14:22 Uhr  ·  #3
Hello Rolf, thanks for considering it.
I have really meant that {$IGNORE_DEBUG_BREAK} switch should instruct compiler to not compile "Debug_Break" instruction at all. {$ENABLE_DEBUG_BREAK} would be default define and it would tell AvrCo compiler to really compile "Debug_Break" instruction into code. That way I could have portions of code that are already debugged and running well for some time having it's many"Debug_Break" instructions not compiled at all, but when I introduce some new features I would like to make these old "Debug_Break" instructions live again and probably introduce some new. {$IFDEF} is too clumsy for this purpose.
Gepostet: 04.12.2014 - 15:02 Uhr  ·  #4
Hello,
why not use conditional compilation
{$DEFINE DEBUG}
{$IFDEF DEBUG} Debug_Break; {$ENDIF}
Gepostet: 04.12.2014 - 16:53 Uhr  ·  #5
Hello Avra,
I will try to implement it.
But to avoid SIM/Debug problems the underlying ASM break instruction must be
temporaly replaced by an NOP
Gepostet: 04.12.2014 - 21:05 Uhr  ·  #6
@Thomas.AC:
I already use it like that but code is so unreadable when there are so many {$IFDEFs}.
@Rolf:
NOP is quite acceptable, thanks!
Gepostet: 09.12.2014 - 11:12 Uhr  ·  #7
define your own Debug procedure and use optimization Switch {$OPTI ALLOW_INLINE}
program test;
{ $W+}
{$DEFINE DEBUG}
Device = xmega128A1U, VCC = 3.3;
    Override_Fuses;
    NoteBook   = A;
    COMport    = USB;
    FuseBits5  = [BODLEVEL1, BODLEVEL2, BODACT0]; // BOD=2.8V if USB variant
    ProgFuses = true;
    ProgEEprom = true;
Import ;
    OSCtype = extXTAL=8000000, PLLmul=4, prescA=1, prescB=1, prescC=1, faildet;
    StackSize      = 256, iData;
    FrameSize      = 256, iData;
implementation
Main Program
procedure myDebugBreak;
  {$IFDEF DEBUG}
  Debug_Break;
  {$ENDIF}
   myDebugBreak;
end test.
Gepostet: 09.12.2014 - 11:42 Uhr  ·  #8
I can see three problems with this.
1. when wanted the break will occur far away from where it is wanted. OK you can step through until you hit the return, but even so it is not very convenient.
2. There could be timing issues, particularly when used with the optimiser, since if DEBUG is not defined the optimiser will remove the function completely together with calls to it. I admit that this is unlikely to be a real problem, though.
3. This is very much an all or nothing approach. I believe that what Avra wants to do is have lots of Debug_Break statements but only have a few of them active at a time. This approach does not allow that.
Having said all that and playing devil's advocate here, I am not sure that Avra's request will gain what he imagines. My own approach would be (and has been) to comment out temporarily unwanted Debug_Breaks with a double slash
  //Debug_Break;
This maintains readability and allows specific debug_breaks to be enabled/disabled at will, and I think with no more work than Avra's suggestion.
MySQL Queries: 8 · Cache Hits: 14   129   143 · Page-Gen-Time: 0.01817s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
