StrToFloat bug report
Gepostet: 30.03.2015 - 15:59 Uhr  ·  #1
Conversion from string to float seams to error in exponent calculation. Problem exists with and without simulator.
  f: float;
  s: string[50];
    s := '      12345678.9'; // x1
    f := StrToFloat(s);
    s := s + ' = ' + FloatToStr(f) + '   ';
    WriteLn(LCDout, s);      // '12345678.9 = 1.234568E7' (good)
    s := '    1234567890.0'; // x100
    f := StrToFloat(s);
    WriteLn(LCDout, s);      // '1234567890.0 = 1.234568E8' (<<< bad, E8 should be E9 !!!)
    s := '12345678900000.0'; // x1.000.000
    f := StrToFloat(s);
    WriteLn(LCDout, s);      // '12345678900000.0 = 1.272353E12' ((<<< bad, E12 should be E13 !!!)
Re: StrToFloat bug report
Gepostet: 07.04.2015 - 14:29 Uhr  ·  #2
Hello Avra,
I tried to find the bug. But the driver is completely written in ASM and
I could not locate the problem. I'm somewhat baffled. Sorry.
Gepostet: 07.04.2015 - 18:27 Uhr  ·  #3
just tested with my 3.98 compiler build ....
same problem .... and the first value is converted to 12345678 without exponent
(all only in simulator)
just a remark: the mantissa of the third value in avra's post looks a little bit mixed-up - maybe a problem with frame size or so?
Gepostet: 07.04.2015 - 19:07 Uhr  ·  #4
Hello Harald,
sorry. I really don't know what is going on there.
It is many, many years ago and all written in ASM. :aerger:
Gepostet: 07.04.2015 - 22:52 Uhr  ·  #5
so ... little bit of ASM-practice helps sometimes ...
this problem occurs only if you use large numbers (more than 8 digits) in non-scientific notation.
lets say 123456.7e13 works good, 12345670000000 doesnt work.
i fear, the same type of error will occure if you convert very small numbers in non-scientific, e.g. 1e-15 will work, 0.000000000000001 might not
i dont know if this is a real "error", because
transferring large strings on a microcontroller with restricted size of RAM is no good idea - stack and frame will catch more space than available, especially when you use some recursive calls.
@rolf:
maybe, one additional inc _accahi at the end of the Str2Flt4-code directly before the str2flt6 entrypoint will fix the problem .... but do some checkout with different sizes of stringnumbers and decimalpoint positions ... i'm still analyzing
Gepostet: 09.04.2015 - 20:16 Uhr  ·  #6
I will reimplement StrToFloat when I catch time...
Gepostet: 10.04.2015 - 14:13 Uhr  ·  #7
Hello Avra,
a Pascal replacement of the StrToFloat function doesn't help.
The bug must be removed in our code generator (ASM) in the
AVRco. User Harald_K already tries to find the bug.
Gepostet: 11.04.2015 - 20:16 Uhr  ·  #8
@Avra,
StrToFloat bug is fixed now.
MySQL Queries: 15 · Cache Hits: 14   131   145 · Page-Gen-Time: 0.020327s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
