Const array as a parameter
Gepostet: 13.10.2017 - 11:46 Uhr  ·  #1
The following does not compile
program Bug;
Device = mega128, VCC=5;
//  Override_Fuses;
  NoteBook   = B;
  COMport    = USB;
  LockBits0  = [];
  FuseBits0  = [];
  FuseBits1  = [SPIEN, OCDEN];
  FuseBits2  = [];
Import SysTick, LCDport;
From System Import Float;
  ProcClock      = 4608000;        {Hertz}
  LCDport        = PortA;
  LCDtype        = 44780;
  LCDrows        = 2;              {rows}
  LCDcolumns     = 40;             {columns per line}
  cTest : array[0..7] of byte =          ( %01010,
                                           %01010,
                                           %01010,
                                           %01010,
                                           %01010,
                                           %01010,
                                           %01010,
                                           %01010);
procedure RegisterSpecialChar( pChar: array[0..7] of byte );
  LCDCharSet( #7, pChar[ 0 ],
                  pChar[ 1 ],
                  pChar[ 2 ],
                  pChar[ 3 ],
                  pChar[ 4 ],
                  pChar[ 5 ],
                  pChar[ 6 ],
                  pChar[ 7 ] );
  RegisterSpecialChar( cTest );
end Bug.
I get the error 'Array of type BYTE expected' in the second to bottom line. But cTest is an array of type byte. I get the same error for memory (structconst) variables too.
Re: Const array as a parameter
Gepostet: 13.10.2017 - 13:09 Uhr  ·  #2
Hi Merlin,
ctest ist not the same type as your declaration pchar.
You must write:
Type
  Ttest : Array[0..7] of byte;
Const
  ctest : tTest = (........)
procedure RegisterSpecialChar( pChar: TTest);
RegisterSpecialChar(ctest);
Gepostet: 13.10.2017 - 14:31 Uhr  ·  #3
How are they different?
I am happy to follow your advice, but if I change things slightly
procedure RegisterSpecialChar( var pChar: array[0..7] of byte );
this does compile. (Not sure if it actually works...)
If you are saying that I am not allowed to pass an array, the surely the error should be in the declaration of the function, not in the call of it?
Gepostet: 13.10.2017 - 16:36 Uhr  ·  #4
even though cTest and PChar are of the same construction, for the
compiler they aren't of the same type!
For arrays and records it makes sense to declare them as types
before you use them as Vars or Const, like Miparo states.
An exception maybe your (var pChar ...). This is a pointer in realty
where the restrictions of usage are somewhat relaxed.
"not passing an array" was not the content of Miparos statement.
Of course it can be used, but simply use predefined types....
Gepostet: 13.10.2017 - 17:06 Uhr  ·  #5
Hi Rolf.
Sorry, perhaps I was not clear. Obviously declaring a type that is a an array and passing that type is passing an array. Also I am very happy with the solution. After all you need to do that in Delphi too.
What I was really getting at is that if you declare
there seems to be no sensible of calling it, so I would prefer it if the error was flagged at the function declaration, not at the attempt to call it. The error produced let me down the wrong path.
Still, the issue is resolved and that is the important thing.
Gepostet: 15.10.2017 - 19:21 Uhr  ·  #6
yes, you are right. I makes no sense to allow such a construction
as a calling argument in a procedure. Maybe I will flag it in the future.
MySQL Queries: 15 · Cache Hits: 14   108   122 · Page-Gen-Time: 0.023311s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
