Democode BootCheckSum fehlerhaft
Gepostet: 08.06.2018 - 12:01 Uhr  ·  #1
Der Democode BootCheckSums funktioniert in der Praxis nicht, da
die globalen Variablen
_CalcFlashPageA
_CalcFlashAddrA
_CalcFlashCA
nach einem "power on reset" nicht initialisiert sind. CalcFlashCheck_A schlägt fehl.
Abhilfe schafft z.B.
  _CalcFlashPageA := 0;
  _CalcFlashAddrA := 0;
  _CalcFlashCA    := 0;
  repeat
    bc:= CalcFlashCheck_A($1000);   // BUG: NO RAM INIT DONE BEFORE, FlashCheck fails
  until bc <> 0;
oder eine Komplettinitialisierung des RAMs vorher.
Bitte das Demo verbessern.
program BootCheckSums;
{ $W+ Warnings}            {Warnings off}
// Device = mega32, VCC = 5;
// {$BOOTRST $03E00}         {Reset Jump to $03E00}     // word address
Device = mega128, VCC=5;
{$BOOTRST $0F000}            {Reset Jump to $0F000 = $1E000}
Import SysTick, SerPort, Flashwrite;
From System Import FlashCheck_B, FlashCheck_A, FlashCheck_S, BootVectors;
  ProcClock               = 8000000;        {Hertz}
  SysTick                 = 10;             {msec}
  StackSize               = $0128, iData;
  FrameSize               = $0108, iData;
  SerPort                 = 19200;
  TxBuffer                = 100, iData;
  FlashChkSum             = (2 * BOOTRST) -2;      // byte addr of checksum placement
                                                   // at app area end, required for FlashCheck_A
Const
// mega32
//  BootCheckF[$7BF8]       : Word      = $AA55;   // byte address, last 6bytes used
// {$PHASE BootBlock $03E00}                       // word address
// mega128
{$PHASE BootBlock $0F000}
  ConstPage   : byte   = 1;
  BootCheckF[$1DFF8]   : word = $AA55;
  bc            : byte;
procedure BootTest;
{$IFNDEF BootVectors}
  // without BootVectors we need a working stack/frame pointer
  Boot_Init;
{$ENDIF}
  // we can use a port bit which the user can pull down
  // to force a flash download
  // check the Boot Checksum
  if not CalcFlashCheck_B then
    nop;
    // big problem !!!!!!!
{ mega32
  ASM;
   ; check last self programming valid
    LDI       _ACCCLO, %.BOOTCHECKF AND 0FFh
    LDI       _ACCCHI, %.BOOTCHECKF SHRB 8
    LPM       _ACCA, Z+
    CPI       _ACCA, 055h
    BRNE      BootTestX
    LPM       _ACCA, Z+
    CPI       _ACCA, 0AAh
    BRNE      BootTestX
  ENDASM;
// mega128
  ASM;
    ELPM      _ACCA, Z+
    CPI       _ACCA, 055h
    BRNE      BootTestX
    ELPM      _ACCA, Z+
    CPI       _ACCA, 0AAh
    BRNE      BootTestX
  ENDASM;
  // now calc the application checksum
  repeat
  until bc <> 0;
  case bc of
    1 : // check ok
    2 : // check failed !
        // what shall we do now ?
        // jump to the Downloader ?
        FlashDownloader;
  endcase;
  ASM;
    // normal program start
    JMP       0000h;
    BootTestX:
    // check failed, try to download
  ENDASM;
  FlashDownloader;
Procedure BootEntry;
  FLASHDOWNLOADER;
procedure FlashLoaderInit;
  ASM;
   ; > > SERPORT Init < <
   ; > > Baudrate 19200Baud < <
   ; > > Parameters are clock and CPU type dependent !! < <
    LDI       _ACCA, 018h; Rx and Tx enanable, polling
    OUT       ucr1, _ACCA;
    LDI       _ACCA, 0; // 00Ch; 38400 Baud
    OUT       ubrr1, _ACCA;
    SBI       ucr1, 1; 2 stop bits
    SBI       ucr1, 0; 2. stopbit = 0
  ENDASM;
procedure FlashLoaderRecv;
  ASM;
    SBIS      usr1, 7; Receiver ready?
    RJMP      %.FLASHLOADERRECV; if not
    IN        _ACCA, udr1
  ENDASM;
procedure FlashLoaderTransm;
  ASM;
    SBI       usr1, 6; clear Transmitter empty
  FLDRTXLP0:
    SBIS      usr1, 5; Transmitter ready?
    RJMP      FLDRTXLP0; if not
    OUT       udr1, _ACCA
  FLDRTXLP1:
    SBIS      usr1, 6; Transmitter empty?
    RJMP      FLDRTXLP1; if not
    SBI       usr1, 6; Transmitter empty?
  ENDASM;
procedure FlashLoaderExit;
  ASM: JMP    System.VectTab;
{$DEPHASE BootBlock}
Const
Type
  bb         : byte;
// Main
  repeat
    bb:= CalcFlashCheck_S($1000);
  until bb <> 0;
  case bb of
    1 : // check ok
    2 : // check failed
  endcase;
end BootCheckSums.
Re: Democode BootCheckSum fehlerhaft
Gepostet: 08.06.2018 - 13:24 Uhr  ·  #2
vielen Dank für die Info
MySQL Queries: 15 · Cache Hits: 14   51   65 · Page-Gen-Time: 0.015946s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
