F16_32 Text Files: Merlin Problem
ReadLn(a_file, a_string) reads only zeroes if optimized
bovist
Homepage: shop.keyboardpartn…
Gepostet: 20.07.2018 - 00:10 Uhr  ·  #1
Hi Merlin,
updated to AVRCo Rev. 5.09.42 and experienced a problem when reading text files from SD card using FAT16_32. Even sample program in Profi Driver manual does not work, ReadLn(a_file, a_string) reads only zeros.
It works when I disable the following Optimizer options:
{$OPTI NO_LOOP_OPT}
{$OPTI NO_BRANCH_OPT}
{$OPTI NO_CSE_OPT}
{$OPTI NO_CALL_FRAME_OPT_LOCAL}
Debug info is attached.
Re: F16_32 Text Files: Merlin Problem
Gepostet: 20.07.2018 - 10:47 Uhr  ·  #2
OK Carsten. I'll look into it.
Gepostet: 20.07.2018 - 12:51 Uhr  ·  #3
Hi Carsten.
I have sent via pm a potential fix. However I need the asm/dsm files to check properly. Can you either send me the asm/dsm files so that I can check, or install the new version and check yourself, and let me know.
Thanks
bovist
Gepostet: 23.07.2018 - 15:00 Uhr  ·  #4
Hallo Merlin,
Mit Optimizer Version v3.5.12.0 funzt es. Danke für die schnelle Hilfe!
Bug fixed with optimizer version v3.5.12.0. Thx!
MySQL Queries: 8 · Cache Hits: 14   80   94 · Page-Gen-Time: 0.016383s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
