Xmega32D4 TWIE
Maugan
Xmega32D4 TWIE
Gepostet: 20.09.2018 - 14:45 Uhr  ·  #1
Hello,
I'm working with a microcontroller ATXmega32D4. I would like to use the TWIE (I2C port E) to communicate with others circuits boards. I have no signal even though I use the TWIC, It's working.
You could find my program (attachment).
Please, why do I can't use TWIE ?
It can't be a hardware problem because the when I use the TWIC it's working.
Thank's
Re: Xmega32D4 TWIE
Gepostet: 20.09.2018 - 15:07 Uhr  ·  #2
Zitat geschrieben von Maugan
Hello,
Thank's
Hello Maugan,
I do not know this CPU, but I once made my look in the datasheet,
which revision do you have?
On page 310, chapter 34.1.5, "TWIE is not available"
But you can use it with a software solution to these PINs, check out the manual "I2CPORT". If your revision of the TWIE does not work, a software interface is a possible solution or another CPU.
Maugan
Re: Xmega32D4 TWIE
Gepostet: 25.09.2018 - 14:24 Uhr  ·  #3
Hello,
Thank you for your answer. Actually, you're right, I didn't use the good version of the microcontroller.
Tahnk's
Re: Xmega32D4 TWIE
Gepostet: 25.09.2018 - 18:45 Uhr  ·  #4
Hello Maugan,
no problem, did you test the software solution and did it work with it?
MySQL Queries: 8 · Cache Hits: 14   82   96 · Page-Gen-Time: 0.017918s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
