[BUG] file system
[BUG] file system
Gepostet: 01.10.2018 - 14:45 Uhr  ·  #1
Das Lesen einer Datei über Blockread bricht bei mir nach 24477696 gelesenen Bytes ab.
Die Funktion liefert ein false zurück, obwohl die Datei noch nicht komplett gelesen wurde.
Kann das jemand bestätigen?
Ausgabe Terminalprogramm
size of Alarm1.wav = 38400124<r><n>
calculate crc of Alarm1.wav<r><n>
file system io error while calculating CRC<r><n>
block count = 47808<r><n>
byte count old = 512<r><n>
byte count = 0<r><n>
Testcode
program calcCRC;
Device = xmega128A4U, VCC = 3.3; // only USB version supports crc module
define_fuses
  Override_Fuses;
  NoteBook   = A;
  COMport    = USB;
  FuseBits1  = [WDPER0, WDPER2]; // watchdog = 8s
  FuseBits4  = [WDLOCK];
  FuseBits5  = [BODACT0, BODLEVEL0, BODLEVEL1, BODLEVEL2]; // BOD = 3V
  ProgFuses  = true;
Import SysTick, SerportE0, FAT16_32, XMega_CRC;
From SysTick Import SystemTime16;
From System Import longword;
define
  OSCtype         = extXTAL = 4096000, PLLmul = 15, prescA = 2, prescB = 1, prescC = 1;
  SysTick         = 10;
  StackSize       = 256, iData;
  FrameSize       = 384, iData;
  SerPortE0       = 115200, Stop1;  // debug connection
  FAT16           = SPI_D, PortD.4, iData; // SPI_X, SS-Port, SS-PIN, data area
  F16_FileHandles = 4;
  F16_DirLevels   = 2;
  F16_MMCspeed    = superfast; // standard, slow, fast, superfast  (fat32)
  F16_StrLen      = 80; // buffer for Writeln to files
uses UFAT16_32;
implementation
  BLOCKSIZE : word = 512;
  tFileBuffer = array[0..BLOCKSIZE-1] of byte;
  fileforCRC              : file of byte;
  filebuffer              : tFileBuffer;
function calculateCRC : boolean;
  fname : TFileName;
  blockCount : longWord;
  fSize : longword;
  byteCount_old : word;
  byteCount : word;
  fsStatus : boolean;
  fname := 'Alarm1.wav';
  if F16_FileSize('', fname, fSize) then
    Writeln(SeroutE0, 'size of ' + fname + ' = ' + LongToStr(fSize));
    Writeln(SeroutE0, 'F16_fileSize failed');
  Writeln(SeroutE0, 'calculate crc of ' + fname);
  if not F16_FileAssign(fileforCRC, '', fname) then
    Writeln(SeroutE0, 'open ' + fname + ' failed');
    return(false);
  if not F16_FileReset(fileforCRC) then
    Writeln(SeroutE0, 'file reset failed');
    F16_FileClose(fileforCRC);
    return(false);
  // calculate crc
  blockCount := 0;
  while not F16_EndOfFile(fileforCRC) do
    ASM: WDR;
    fsStatus := F16_BlockRead(fileforCRC, @filebuffer, Sizeof(filebuffer), byteCount); // long timeout
    if fsStatus = false then
      // file system io error
      Writeln(SeroutE0, 'file system io error while calculating CRC');
      Writeln(SeroutE0, 'block count = ' + LongToStr(blockCount));
      Writeln(SeroutE0, 'byte count old = ' + IntToStr(byteCount_old));
      Writeln(SeroutE0, 'byte count = ' + IntToStr(byteCount));
      return(false);
      inc(blockCount);
     // add bytes to crc calculation
    byteCount_old := byteCount;
  endwhile;
  return(true);
// main
    ASM: WDR;
    while not F16_DiskInit do
      Writeln(SeroutE0, 'disk init failed');
      mDelay(1000);
    endwhile;
    if not F16_DiskReset then
      Writeln(SeroutE0, 'disk failed');
      calculateCRC;
end.
Re: [BUG] file system
Gepostet: 01.10.2018 - 15:23 Uhr  ·  #2
das sieht irgendwie nach einer Grenze von 2^31 aus, longword.
Möglicherweise ein Limit im Filesystem?
Gepostet: 01.10.2018 - 16:16 Uhr  ·  #3
Hallo Rolf
Die Testdatei ist 36,6 MB.
Das sollte für longword kein Problem sein
Gepostet: 01.10.2018 - 16:21 Uhr  ·  #4
stimmt, ich habe mich da um ein paar stellen vertan :-(
Aber ich habe da momentan keine Idee
Gepostet: 12.10.2018 - 20:53 Uhr  ·  #5
Nachtrag: Die genaue Position hängt vom Zustand des Dateisystems auf der SD Karte ab (Fragmentierung). Der Fehler tritt bei FAT16 sowie auch FAT32 formatierten Karten auf. Wenn der Fehler auftritt, dann immer an der selben Position.
MySQL Queries: 8 · Cache Hits: 14   97   111 · Page-Gen-Time: 0.012947s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
