Problemchen bei der Suche in allen Dateien
  • Page 2 of 2
Re: Problemchen bei der Suche in allen Dateien
Posted: 15.10.2019 - 14:33  ·  #9
Hi Merlin,
please attach ../AVRco/Setup-Log-AVRco_<date>.txt
Posted: 15.10.2019 - 18:03  ·  #10
Hi Gunter.
Attached as requested.
SetupMode: 32 Bit
Sys: Version9x=0, VersionNT=1000, VersionNT64=1000, NTProductType=2, SevicePack=0, CPU=x64, VM=0
CMDString:
Info: 15.10.19-08:39:14, Produkt:AVRco V5.10.06/2, Installer (Update) V4.6.800, CurrentUser: Administrator, InstallType: Computer
>GetSysDir: Folder CSIDL_WINDOWS (1) C:\Windows\
>GetSysDir: Folder CSIDL_PROGRAM_FILES (1) C:\Program Files (x86)\
>GetSysDir: Folder CSIDL_COMMON_DESKTOPDIRECTORY (1) C:\Users\Public\Desktop\
>GetSysDir: Folder CSIDL_COMMON_FAVORITES (1) C:\Users\dsm\Favorites\
>GetSysDir: Folder CSIDL_COMMON_STARTUP (1) C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp\
>GetSysDir: Folder CSIDL_COMMON_APPDATA (1) C:\ProgramData\
>GetSysDir: Folder CSIDL_APPDATA (1) C:\Users\dsm\AppData\Roaming\
>GetSysDir: Folder CSIDL_PERSONAL (1) C:\Users\dsm\Documents\
>GetSysDir: Folder CSIDL_FONTS (1) C:\Windows\Fonts\
>GetSysDir: Folder CSIDL_PROGRAM_FILES_COMMON (1) C:\Program Files (x86)\Common Files\
>GetSysDir: Folder CSIDL_COMMON_DOCUMENTS (1) C:\Users\Public\Documents\
>GetSysDir: Folder CSIDL_LOCAL_APPDATA (1) C:\Users\dsm\AppData\Local\
>GetSysDir: Folder CSIDL_PROFILE (1) C:\Users\dsm\
>GetSysDir: Folder CSIDL_SENDTO (1) C:\Users\dsm\AppData\Roaming\Microsoft\Windows\SendTo\
>GetSysDir: Folder CSIDL_COMMON_PROGRAMS (1) C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Extension: Init Extension-Dlls
Prgstart(PRG): <TEMPDIR>\pshd1.exe
>Startpage: target:0 current:0
>PRG: C:\Users\dsm\AppData\Local\Temp\SetupTemp0\pshd1.exe, PARA:/Language 1033, RESTRICTED: NO
>PRG: ReturnCode: 0
>PRG: Command was executed.
Launch-Condition: True
Extension: IAppSearchExecute has nothing to do, Steps = 0.
Rollback: Determine rollback-backup size...
Extension: Call EXT_Driver, Function: IProcess.
ExtensionCondition: UserPrivileged=2
ExtensionCondition: True
ExtensionCondition: VersionNT64
Filename: SetUp-Log-AVRco_151019.txt
Filesize: 2.57 KB
Title:
Download counter: 4
Posted: 15.10.2019 - 19:33  ·  #11
Quote
File: Decompress-Function failed!!!! Code : -2, File: C:Program Files(x86)/AVRco/IDE/ped32.exe
I tried download/install today and found no problems.
@Rolf
are there recent changes of the installer file?
It seems not (see attachment)
Filename: FTP.png
Filesize: 9.06 KB
Title:
Download counter: 45
Posted: 15.10.2019 - 20:11  ·  #12
Hallo Gunter,
nein. Da war ein Bug im htaccess File.
Woher? Keine Ahnung.
Posted: 16.10.2019 - 15:15  ·  #13
Update hat geklappt.
Die Lösung des Problems ist aber recht simpel gemacht: Sobald man das Projekt wechselt schließt sich das Suchfenster :-(
Das ist leider nicht sehr praktisch. Ich nutze diese Suche über alle Dateien oft um Dinge auszutauschen, von einem Projekt zum nächsten.
Dabei klappere ich dann jeden gefundenen Eintrag ab und kopiere entsprechenden Code um.
Das ist so leider nicht mehr machbar, da müsste ich nach jedem Wechsel die Suche neu starten.
Ideal wäre es, wenn ein Klick auf ein Suchergebnis in das bei der suche gewählte Projekt springt, dazu müsste man nur die bei der Suche gewählten Tab an die Suchergebnisse anhängen, so könnte das Programm dann entsprechend zum richtigen Tab wechseln.
Posted: 01.02.2020 - 11:59  ·  #14
Ich würde das gerne noch mal hervor holen. Seit der Änderung am Fenster klappt es eher schlechter als besser.
Bei mir wird das Fenster oft unterhalb des Editors geöffnet, ich komme dann nur heran indem ich den Editor minimiere und es hervorziehe.
Nicht immer, aber jedes 3-4 Mal landet es hinter dem Editor.
Die letzte Position und Größe des Fensters wird auch nicht gespeichert, es geht immer wieder auf den Hauptmonitor auf, und verdeckt so den Editor.
Das Mausrad zum Scrollen funktioniert da auch nicht, stattdessen bewegt das Mausrad dann den Text im Editor.
Ja, und wenn man auf ein anderes Projekt klickt wird das Suchergebnisfenster geschlossen, was das Kopieren von Code von einem Projekt ins andere sehr erschwert.
Nach wie vor wird der Pfad zur gefundenen Datei nicht verkürzt dargestellt, was bei mir zur Folge hat dass da ein sehr langer Pfad angezeigt wird und das eigentliche Suchergebnis viel zu weit rechts steht.
Vielleicht ist es ja möglich diese überaus nützliche Suchfunktion zu verbessern, das wäre sehr hilfreich.
  • Page 2 of 2
MySQL Queries: 17 · Cache Hits: 15   113   128 · Page-Gen-Time: 0.026826s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
