Tiny412 Compilerfehler
  • Page 3 of 4
Re: Tiny412 Compilerfehler
Posted: 07.01.2022 - 14:52  ·  #17
Posted: 07.01.2022 - 14:54  ·  #18
Perfect. Now no problem :-)
Posted: 07.01.2022 - 15:00  ·  #19
Hi Miparo
Quote
Also Atmel files start from 0!
Forget the EEprom offset in the hex file, it is only used internally.?
Not sure that I understand.
For example, if I leave the offset at $1400 for Tiny412 eep file, the Atemel ICE will accept? That is not what I understood from a user who manually changed the EEPROM offset to zero and then wondered why his program didn't work!
Or are you saying I can adjust to zero and ISP3-X will accept?
Posted: 07.01.2022 - 15:06  ·  #20
attached org ATmel *.epp picture.
All files begin at address 0
"Or are you saying I can adjust to zero and ISP3-X will accept? "
Yes
Posted: 07.01.2022 - 15:21  ·  #21
Thanks Miparo. That is good.
Posted: 07.01.2022 - 18:50  ·  #22
hi Miparo
'I wanted to test the Serport, but then nothing works.'
the serport works (for me without a buffer).
I used the alternative pins. This is poorly documented in the data sheet of the ATTiny412.
'Ich wollte noch den Serport testen, aber dann funktioniert nichts.'
der serport funktioniert doch (bei mir ohne Buffer).
Ich hatte die alternativen Pins genutzt. Das ist schlecht dokumentiert im Datenblatt des ATTiny412.
Posted: 10.01.2022 - 19:57  ·  #23
Hi Miparo
I will include the ISP updates in the next release.
Can I remove all the older updates in the full download to make the download smaller (and hence faster)?
Posted: 11.01.2022 - 18:22  ·  #24
Hi Merlin,
You can delete all old firmware files.
  • Page 3 of 4
MySQL Queries: 16 · Cache Hits: 15   136   151 · Page-Gen-Time: 0.025867s · Memory Usage: 2 MB · GZIP: on · Viewport: SMXL-HiDPI
