New PED
  • Seite 2 von 5
Umfrage
Which do you prefer:
Always launch Old PED/Immer altes PED starten
0 (0%)
Always launch New PED/Neues PED immer starten
4 (66.67%)
Create Chooser program/Chooser-Programm erstellen
2 (33.33%)
Stimmen insgesamt:6
Re: New PED
Gepostet: 12.02.2022 - 12:58 Uhr  ·  #9
since I don't use either the "old" or the "new PED", a choice would be best:
- New PED
- Old PED
- No PED
And preferably a separate update tool/program, like rolf had for a while. This I can then simply include in my UEStudio.
Greetings
Re: New PED
Gepostet: 12.02.2022 - 13:21 Uhr  ·  #10
Hi Thorsten.
What do you mean by a separate update tool? Something that checks the version and advises you if it changes?
I don't have time to do that I am afraid, but I can advise how to do it. Do you still have the old update tool? presumably it would still work.
To have no PED, simply uncheck the launch box after the install, but if I do write a chooser program I will allow the user to select an editor of their own choice (or none!).
So
-New PED
-Old PED
-User Defined
- None
[x] Always do this
Re: New PED
Gepostet: 12.02.2022 - 16:11 Uhr  ·  #11
Zitat geschrieben von Merlin
Hi Thorsten.
So
-New PED
-Old PED
-User Defined
- None
[x] Always do this
Hallo Merlin,
ich meine dieses Tool "AVRcoWebUpdater.exe", evtl. funktioniert es auch noch. Aktuell zeigt es Version 5.11.07 an, keine Ahnung ob das die aktuelle ist.
Das mit Deinen Anpassungen ist so für mich in Ordnung, ich brauche keinen start einer PED-Version.
I mean this Tool "AVRcoWebUpdater.exe", maybe it still works. Currently it shows version 5.11.07, no idea if this is the current one.
Your adjustments are fine for me, I don't need to start a PED version.
Greetings
Re: New PED
Gepostet: 12.02.2022 - 16:47 Uhr  ·  #12
Hi Thorsten
I just uploaded v5.11.07 a few minutes ago, so yes, it looks like it still works.
Re: New PED
Gepostet: 12.02.2022 - 19:45 Uhr  ·  #13
@Merlin: 5.11.07 ..... 837 MByte .... really?
Re: New PED
Gepostet: 12.02.2022 - 19:51 Uhr  ·  #14
Hi Haryr,
32 MB oder meinst du das Full Install ?
Re: New PED
Gepostet: 13.02.2022 - 07:41 Uhr  ·  #15
Moin Miparo,
bei Thorsten oben von der 5.10.09 auf 5.11.07 sinds 837MByte, bei dir von 5.10.10 auf 5.11.07 sinds 32.16MByte. Echt jetzt? Ja das ist offensichtlich ein Full-Update, aber wieso in diesem Fall? Hab mich halt gewundert.
Re: New PED
Gepostet: 13.02.2022 - 11:11 Uhr  ·  #16
Hi Harry
If you update from 5.10.xx to 5.11.xx via the PED, the PED requires you to go for 5.11.00 first, which installs everything, then you install 5.11.xx.
I am using a different installer (because I have to) so it may be an idea to uninstall the old AVRCo first, but you don't really have to. If you download 5.11.07 from the web site and just install that without uninstalling the old version everything should work. v5.11.07 has everything I have changed since taking over the compiler from Rolf. Once you have done that you can update from the PED again.
It is worth commenting that the install files also contain the Windows msi installer, which will increase their size somewhat.
Hallo Harry
Wenn Sie von 5.10.xx auf 5.11.xx über die PED aktualisieren, erfordert die PED Sie für 5.11.00 zuerst gehen, die alles installiert, dann installieren Sie 5.11.xx.
Ich benutze ein anderes Installationsprogramm (weil ich es muss), also könnte es eine Idee sein, das alte AVRCo zuerst zu deinstallieren, aber das muss man nicht wirklich. Wenn Sie 5.11.07 von der Website herunterladen und einfach installieren, ohne die alte Version zu deinstallieren, sollte alles funktionieren. v5.11.07 enthält alles, was ich geändert habe, seit ich den Compiler von Rolf übernommen habe. Wenn Sie das getan haben, können Sie wieder über die PED aktualisieren.
Es ist erwähnenswert, dass die Installationsdateien auch das Windows msi-Installationsprogramm enthalten, was ihre Größe etwas erhöhen wird.
  • Seite 2 von 5
MySQL Queries: 17 · Cache Hits: 14   137   151 · Page-Gen-Time: 0.021516s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
