LCDPORT error on ATMega128 on Compiler 6.00.04
wsandor
Gepostet: 01.08.2024 - 10:12 Uhr  ·  #1
I've just installed V6.00.04 version of AVRCO. Previously I used 5.10.00 for years.
I tried to compile one of my old programs with the new version and run into a probem: On ATMega128, if LCDPORT is defined to PORTF or PORTG then the compiler throws an error: "Error: DEFINE LCDPORT = PortX (x defined in *.dsc) expected". PORTE or lower doesn't give an error.
The error could be reproduced with a minimal, project wizard generated file I attached.
Any idea about what can be the problem?
Re: LCDPORT error on ATMega128 on Compiler 6.00.04
Gepostet: 01.08.2024 - 22:22 Uhr  ·  #2
It is possible that there is an issue with the dsc file. I will check it out.
Gepostet: 01.08.2024 - 22:34 Uhr  ·  #3
For me your sample compiles fine. I attach my dsc file, in case yours is corrupt. If you still have an error I will publish the latest version of the compiler which I was about to publish anyway.
wsandor
Gepostet: 02.08.2024 - 07:58 Uhr  ·  #4
Dear Merlin,
Thanks for your prompt reply. The dsc file is the same I have so unfortunatly the problem lies somwhere else.
Sándor Wortmann
Gepostet: 02.08.2024 - 09:52 Uhr  ·  #5
OK, Here is my latest compiler, about to be released. Could you try that? As I say, your program compiles fine here.
wsandor
Gepostet: 05.08.2024 - 15:49 Uhr  ·  #6
Thanks Merlin! This seems to be solve the problem. Both the test and my original program compiles succesfuly with this new compiler version.
Gepostet: 05.08.2024 - 16:22 Uhr  ·  #7
Good to hear. Thanks for letting me know.
MySQL Queries: 8 · Cache Hits: 14   123   137 · Page-Gen-Time: 0.017558s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
