E-Lab programmer gives Missing CPU name in project error
Alvanicus
Gepostet: 17.06.2025 - 14:51 Uhr  ·  #1
Hello,
I have recently bought a new Windows 11 PC to replace my old Windows 10 PC. I installed the latest version of E-Lab (v6.00.05).
I opened up my project I was working on, and was able to continue writing and compiling the code. However, when I went to program the board, I was unable to. I received a "Missing CPU name in project error".
I then closed the editor and launched the programmer as a separate application. I imported the project file, and when I clicked on it, I received the same error.
I deleted the project, and then imported it again. All the information appeared correct in the text boxes, including the CPU box. However, when I clicked on the CPU box, it came up with a "List index out of bounds [0]" error.
I have attached the ISPE, hex and EEP files.
Any help will be appreciated.
Best regards,
Alvin
Alvanicus
Re: E-Lab programmer gives Missing CPU name in project error
Gepostet: 17.06.2025 - 15:13 Uhr  ·  #2
PS: Sorry for the double post.
I also should have said when I pressed the programmer button from the editor, I get a "HEX not found error".
Alvin
Alvanicus
Gepostet: 17.06.2025 - 15:33 Uhr  ·  #3
Another update.
I was using PED32. When I tried using Ped32New, I do not have this problem. So the solution is just to use Ped32New instead.
Thank you for your time.
Alvin
Gepostet: 17.06.2025 - 19:06 Uhr  ·  #4
Hi Alvanicus,
give the old PED AND AVRprog admin rights then it should work there too.
Otherwise you can simply double click on your uv_base.ispe file and the AVRprog should open and load your project.
Alvanicus
Gepostet: 18.06.2025 - 12:00 Uhr  ·  #5
thank you
MySQL Queries: 15 · Cache Hits: 14   96   110 · Page-Gen-Time: 0.028724s · Speichernutzung: 2 MB · GZIP: ein · Viewport: SMXL-HiDPI
